Engine Fire, Need parts.
I was changing the Carb on my 72 and when I went to start it up all I got was was a huge engine fire... Luckily I had a bucket of water nearby and was able to put it out before the entire Truck went up in smoke. The only damage was to the wire that goes to the temp sending unit, some vacuum hoses, and the throtle cable. Where can I get a new throtle cable? I called all of the local part houses and had no luck. Maybe some vendors carry them. Thanks
Youth soon passes away, but immaturity can last a life time. |
Professional Grade
You're in luck, I've got a throttle cable on my parts truck, I'll pull it off and ship it to you on Monday morning. Just need your address
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
