Old 11-06-2004, 11:16 PM   #1
tnblazerk5
User #12137
tnblazerk5's Avatar
van tilt Question
i have a van tilt i am going to put in a 67 my Question is can i move the whole tilt closer to the dash to give me more arm,belly, room
tnblazerk5 is offline   Reply With Quote
Old 11-06-2004, 11:32 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
To a degree...yes you can. I did that in the Longhorn. I feel the wheel is too close in stock configuration myself.
Don't forget on the van tilt, you'll need the intermediate shaft off a late '68 - '72 truck.
Old 11-06-2004, 11:38 PM   #3
Solver
Solver's Avatar
I just posted earlier about installing 2 tilts today
if you look at the pics they are both installed about 11/2 to 1 3/4" closer to dash than factory.keep in mind that if you do that with a van tilt you may want to adjust where you mount the neutral saftey switch. Maybe 6" up instead of factory distance.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 11-06-2004, 11:44 PM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
my 67 already has the correct intermediate shaft on it i put it there when i put the power steering on it about 20 years ago thanks for the tip though i had to go look at it to make sure i put it in there just to make sure!!!!! how much more room will i have ? and what all will i have to do to move it closer ?
Old 11-06-2004, 11:49 PM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
yes i looked at them and they look really good in there too !!!!!!! my neutral switch is on the tranny i put it there when i put a turbo 350 in it about a year ago !! is there any thing else i need to do ?
Old 11-07-2004, 12:55 AM   #6
Solver
Solver's Avatar
Just get the column in there and then push in to collapse the intermediate shaft to the position you want it.
I pulled the intermediate shaft completely out to remove old column so when I collapsed the shaft I greased it a little and made sure it slide back and forth so once the column is back in and the rag joint is bolted back together you can push and pull till you get it just right.
