Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 11-07-2004, 12:23 AM   #1
Solver
Solver's Avatar
Neutral safety switch van wiring
Seems to be some confusion and don't think this has been addressed
1.First check faqs for remounting neutral safety switch on van column.
2.If you are going to mount column closer to dash than factory you may want to move the location up 1/2 - 3/4" to clear firewall as mounting closer will move switch closer to firewall.
the Neutral safety switch on van is usally different than original pickup tilt so you will have to do some mods if you want switch to operate properly
As you see in the pic the pickup switch has an L shaped setup for backup lights and van has 2 horizontal plugs.
If you are really lucky when you got the column you saved the 2 plugs and can just rewire the ends for the backup lights.
The neutral safety switch doesn''t require a new end
heres 2 different switches
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline
