Old 11-07-2004, 03:24 AM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Changing from drum to disc in front
when u change over from drum to disc brakes can you just bolt on the disc brake spindles to the original a arms or do you have to change the a arms as well?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 11-07-2004, 04:53 AM   #2
GMCPaul
Thumbs up
If using 63-70drop or stock height disc brake conversion spindles you don't need to change anything, if using 71 up spindles unbolt the entire crossmember with a-arms and all steering parts attached up to and including the pitman arm and roll it out from under the donor vehicle then do same on your truck and roll the donor under and bolt it on. Otherwise you will need to swap out upper & lower ball joints in your current a-arms for 71 up style or swap a-arms as you said and rather than unbolting everything from donor individually its much easier to do the swap as a assembly. The lower a-arm on 71 up trucks also has the brake lines to hose mounting tang attached on the front of lower a-arm on 70 and earlier this is attached at the rear of the arm.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-07-2004, 01:34 PM   #3
Blue85
Oilfield Trash
Blue85's Avatar
but the 71 ball joints will work with the old style a arms, or what?
87 Chev 3+3 4x4
Old 11-08-2004, 12:09 AM   #4
HuggerCST
HuggerCST's Avatar
Yes, '71 ball joints will work in your old style a-arms.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 11-08-2004, 12:10 AM   #5
SCOTI
SCOTI's Avatar
71-72 style will work as well as 73-87 ball joints.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-08-2004, 01:46 AM   #6
Blue85
Oilfield Trash
Blue85's Avatar
koo
87 Chev 3+3 4x4
