![]() Join Date: Jul 2000
What shocks for a lowered truck?
I am looking for input on what shocks to use on my 2 1/2" spindle drop and 4" rear coil drop for my truck. (I have used KYB's on my stock height truck and have been happy with them.)
Thanks, Terry ![]()
50 miles west of Syracuse, NY '94 Silverado swb '70 Chevelle '65 Corvette roadster '11 Tahoe (wifes ride) |
senior member
i used belltech they qwork great for me
69 GMC bagged |
The KYB's should work just as well w/the drop. If you like them, why switch?
The dropped spindles won't alter shock length req's. The rear drop springs prob will take some travel out of the shock, but @ 4" of drop they should work. Worst case scenario is you'll need to get rear shock locators.
Scoti,
The KYB's I am using now are on a stock height truck. I can buy them local, but I don't know what application to use. I posted this question on the suspension board and was told that the KYB's for lowered trucks are different than those used for stock height. Thanks, Terry ![]()
Got Light Emitting Diode?
your lower control arm will ride in the same place, it just changes your spindle placement, so a stock ride shock will work in the front. you would need to change the shock if you went with a lowering spring.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
![]() Join Date: Mar 2000
With a 4" rear drop you only need rear shock relocators, no need to change shock, and using 2 1/2" drop spindles means you also do not need to change in the front as drop spindles require a stock height shock.
GMCPaul |
THANKS to all! Terry
