Old 11-07-2004, 07:07 PM   #1
CHEVYE
my gas saver
CHEVYE's Avatar
cleaning frame???
pulled my front end today. i heard a few guys using oven cleaner to clean the frame/suspension. will this eat up the bushings? i want to reuse most of this as it is only 1 1/2 years old. i will be replacing tie rod ends and such though, thanks again for the help, eric.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 11-07-2004, 08:11 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've used it on chassis and engines with no "eating" issues on either.
I also use GUNK engine brite too, works good and cheap, but not near as aggresive as Oven Cleaner is.
Make sure to thoroughly regrease any suspension stuff with lots of new grease to flush out any residual cleaner that may have worked it's way into the part.
Old 11-07-2004, 08:21 PM   #3
roj2323
hey oven cleaner i've never heard of that one. cool idea.
ondrew
roj2323 is offline   Reply With Quote
Old 11-07-2004, 10:11 PM   #4
CHEVYE
my gas saver
CHEVYE's Avatar
tx, you are the man, i`m gonna frame up this truck so you`ll be hearing alot of ?`s from me, thanks again, eric.
71`SWB, project
ebay feedback
Old 11-07-2004, 10:21 PM   #5
Sweet72
Sweet72's Avatar
Engine cleaner (gunk I think) and a borrowed pressure washer worked great for me.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
