Old 11-07-2004, 08:50 PM   #1
dwaite72lnghrn
Heater core today!!
I changed the heater core today. A few pictures of the change out. New heat core from GMC Paul next to the old unit and the empty spot. It took me about 2 hours, I also had to epoxy one of the mount screws back on that I b roke about 14 years ago.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 11-07-2004, 08:55 PM   #2
gr8scott51
gr8scott51's Avatar
So that's the a/c type. I didn't realize you had to drop the inner fender for that one, too. Jewels took some nice pics of the non-a/c unit about the same time I changed mine. They should both be in the FAQs.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-07-2004, 09:41 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I replaced my A/C type heater core several years ago. Luckily for me (?!?) I can't recall much about the procedure except that it seemed like a big PITA. Then again, I know for sure I didn't drop the inner fender. Might have made the job a bit easier!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-07-2004, 11:31 PM   #4
skokie
skokie's Avatar
I was doing that this sat and had to stop in my tracks cause my blower moter gasket is shredded. One I get the new one I can put it all back together.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-07-2004, 11:33 PM   #5
dwaite72lnghrn
I changed the blower relay on the box today also. It's nice to have a high setting again.
2009 HHR aqua blue
Dave & Jeanne
Old 11-07-2004, 11:33 PM   #6
Swbman
I just changed the one in my 71 suburban about a week ago,since it has ac all I had to do was pull the inner heater core box located under glove box,about five barrel screws have to be removed under the hood around the ac dog house, the only time you have to remove the right fender is when its a non ac truck,theres I believe one or two bolts that can only be removed with the fender lowered or removed.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 11-08-2004, 02:22 PM   #7
meathead95
computer illiterate
meathead95's Avatar
got a pic of the blower relay switch? i dont have high on my blazer and maybe thats why.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-08-2004, 09:55 PM   #8
dwaite72lnghrn
This is an airconditioner blower relay. top and side. It mounts to the right side of the inside heater box.
2009 HHR aqua blue
Dave & Jeanne
Old 11-09-2004, 04:02 PM   #9
meathead95
computer illiterate
meathead95's Avatar
cool it will make a difference in how hard the air blows correct? can i get it at autozone or where?
thanks
keith
72 2wd blazer
72 swb 4x4
Old 11-09-2004, 07:48 PM   #10
dwaite72lnghrn
My relay would make a sound like a spring snapping when I put the switch to HIGH. The first and second position worked fine. It really hepls the defrost the windsheild. I got it through GMC Paul when I ordered the heater core. I don't think you should have a problem getting it at AutoZone or NAPA. I didn't try there, had to wait for a core anyway.
2009 HHR aqua blue
Dave & Jeanne
Old 11-09-2004, 08:10 PM   #11
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'm having the same problem with my heater - only low and mid, no high. I changed the resistor out this weekend but it didn't fix the problem. My next step was going to be the switch, but it sounds like I should change this relay out first. THANKS!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-09-2004, 09:08 PM   #12
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
boy this must have been bad carma or something.I had to do mine today.It blew and fogged the whole inside of the truck,and the taste was terrible
Someone had torched a couple of holes in the fenderwell though so the bottom bolts were a snap. It's an AC cab,with a non AC heaterbox,go figure
Took me 45 minutes including the trip to autozone
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
