Old 11-07-2004, 09:19 PM   #1
teamharvey
teamharvey's Avatar
Defrost vents
Has anyone else had problems with after market vents not fitting, not even close ?
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 11-07-2004, 10:18 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Mine went right in, once I figured out the left from the right.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-08-2004, 04:40 AM   #3
GMCPaul
They are installed in over 1/2 of our trucks with no problems.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-08-2004, 09:42 AM   #4
teamharvey
teamharvey's Avatar
Thanks, I must be putting them in wrong.
Bret
1 incredible wife
2 great kids
Old 11-08-2004, 10:52 PM   #5
teamharvey
teamharvey's Avatar
Ok, no laughing here...! They are marked LH and RH. Is LH the drivers side and RH the passenger side ?
Thanks,
Bret
1 incredible wife
2 great kids
Old 11-08-2004, 10:55 PM   #6
BurnoutNova
BurnoutNova's Avatar
with anything automotive that is marked LH and RH imagine your sitting in the drivers seat... smae with brakes, lights, whatever... driver is left, pass is right
zach
BurnoutNova is offline   Reply With Quote
Old 11-08-2004, 10:56 PM   #7
useRc10
useRc10's Avatar
yup...LH from the viewpoint of the driverseat is the drivers side
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 11-08-2004, 10:58 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I remember GM vents have one round port and the other oblong port.
I don't remember which goes on which side though. I'm sure someone will chime in with that info.
Old 11-08-2004, 11:06 PM   #9
rickspickuppart
round on the left
rickspickuppart is offline   Reply With Quote
Old 11-08-2004, 11:11 PM   #10
teamharvey
teamharvey's Avatar
Thanks guys.....
1 incredible wife
2 great kids
Old 11-09-2004, 03:08 AM   #11
GMCPaul
Thumbs up
Heres a tip to make sure your hoses install fully so they do not blow off when turned on, on the outlets of your heater box for the defrost hose you will see 3 small tabs sticking up that the hose needs to slide over to prevent them from blowing off when turned on, if you try to just push it on the majority of time it will not slide over the retention tangs, so rotate the hose in a clockwise manner while pushing it on the outlets this allows the wire in hose to thread its way around onto the tabs, after installing the hose on the box extend the drivers side hose through hole in top of dash and thread defroster vent onto hose in the same method, on passengerside extend hose through dash then grasp hose and squeeze into a oval shape being sure not to catch any hose material on lip of vent insert vent inlet into hose then press firmly while rotating clockwise slowly and you'll thread the hose on.
Be cetain you get the wire in hose past all 3 tabs used to retain hose otherwise be prepared to reinstall on a regular basis as they will blow off.
GMCPaul
Old 11-09-2004, 09:50 AM   #12
teamharvey
teamharvey's Avatar
Thanks GMCPaul, this type of info is why I am hooked on this board !
1 incredible wife
2 great kids
Old 11-13-2004, 12:17 AM   #13
duke10
Active Member
duke10's Avatar
thanks for the tips on the hoses
duke10 is offline   Reply With Quote
