Old 11-07-2004, 09:44 PM   #1
wolfthing2000
69 door hinge
The door hinge mount at the door sheetmetal is cracked out ( about an inch) not bad at this point. Is there any re- inforcement repair or just weld up the crack.??
Dave
wolfthing2000 is offline   Reply With Quote
Old 11-07-2004, 10:17 PM   #2
Sweet72
Sweet72's Avatar
I'm not aware of any reinforcements for this. My GMC driver door was cracked near the upper hinge when I bought it. Just remove the hinge from the door side straighten if necessary and weld it up.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-07-2004, 10:28 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
One thing we do in aircraft is to drill a 1/8" hole at both ends of the crack before repairs. Stops the crack from growing in fatigue prone areas. I would also vee the crack with a cutoff wheel before welding, so you get good penetration. Also weld up the holes at the crack ends.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-08-2004, 01:08 PM   #4
wolfthing2000
Thank you for info. I will drill crack ends aND WELD.
Dave
