Old 11-07-2004, 09:54 PM   #1
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
lowering question
fellow chevers, I am stumped. My truck a 76 stepside was bought from someone already lowered, after lots of tracking down I discovered that the previous owners did a flip on the rear and cut 1 1/2 inch out of the front spring, no I am actually doing a full resto on this truck and upon tearing apart the front end I have come to discover that the spring is loose inside the upper and lower arms, is this ok? My question about this would be that if I was driving down West Virginia roads (bad, bad roads) wouldn't that spring bounce around alot. Also, while I have your attention I guess that I should mention the the previous owners also set the rear end above the leafs (a flip..right?) Is this ok, any help would be much appreciated, thanks!!!
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 11-07-2004, 10:18 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
You mean to say the coil is flopping around when the truck is on the ground? If so, no, this is not OK. When I jack my truck up the 1.5" drop coils will come out of the top control arm a little but it doesn't flop around.
On the flip, how did he do it? Is it done correctly? You have some close up pics of it?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-07-2004, 10:28 PM   #3
AspecialZ
AspecialZ's Avatar
no, when it's jacked up it will rattle around, I just didn't know what the deal was, I was thinking if I hit a bump it would wear out the a-arm, just wondering if this is a good idea or not, I'm not sure if I have a better picture to be honest with you, but i'll look around.
Old 11-07-2004, 10:32 PM   #4
AspecialZ
AspecialZ's Avatar
rear end flip
found a better one...
Old 11-08-2004, 12:09 AM   #5
ocbaud
Garage Queen Material
from what i can see, it looks like he had the spring perches rewelded on the bottom of the axle, which should be fine. you will want to run some shock extenders and possibly some drop shocks along with them.
ocbaud is offline   Reply With Quote
Old 11-08-2004, 12:55 AM   #6
1FaastC10
1FaastC10's Avatar
unless of course he wants to go stock, at which point he can cut em off, and weld em back where they go.
1FaastC10 is offline   Reply With Quote
Old 11-08-2004, 12:59 AM   #7
ocbaud
stfu.
i swear, its like every reply that someone makes towards a post of mine, you are all trying to just get those magical 4 letters out of me
Old 11-08-2004, 01:16 AM   #8
TIMSPEED
TIMSPEED's Avatar
As an observation...those two crossmembers on TOP of the frame...only stepsides have that, right?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-08-2004, 05:40 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
No, Fleets have them too, they are just welded to the bottom of the box. On stepsides they are bolted through the wood.
The rear flip is perfectly fine. and if I am reading it correctly on the front springs that the move when the truck is lifted only, then you are fine there also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-08-2004, 06:03 PM   #10
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
If your not going to put a C-notch in it, move that pass side brake line before you smash it on the frame.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
