Old 11-07-2004, 11:41 PM   #1
Alexis
Member since 2000
Alexis's Avatar
Spark plug thread gone.
well my buddys ford took a dump on him. It seems who ever did the first tune up didn't do it right. One of the spark plugs stripped the threads.......how can this be fixed.
Alexis is offline   Reply With Quote
Old 11-08-2004, 12:00 AM   #2
dwaite72lnghrn
I think most auto stores have a repair kit for it, like Heli-coil.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 11-08-2004, 12:05 AM   #3
Alexis
Member since 2000
Alexis's Avatar
do it your self or get a shop?
it's a 99 crown vic 4.6L. The plugs actually go into a slot, so you need a extension to get the sparkplug lose and a magnet to pull it up. Seems alot of items have to come off the motor to get the job done right. We got a buddy who has a connection but won;t know till monday if it's a go or not. I rather have the info at hand if he doesn't pull through.
Old 11-08-2004, 12:15 AM   #4
dwaite72lnghrn
I had a safari van that had a plug thread break off in it, I sent it to a shop and the cost was $750 they had to pull the head to drill it out. I don't really like working on the new engines because you spend 3 times more effort just getting to the real problem and then you have to put all the hoses wires and plastic covers back on.
2009 HHR aqua blue
Dave & Jeanne
Old 11-08-2004, 01:43 AM   #5
RON WOODGEARD
Resident Young Old Dude !
It takes a pretty good sized tap, and you need to drill and tap it to put the Heli-coil in it.. But you will save a lot of money if you guys remove the head and take it to a machine shop.. Let them do the machine work then reassemble yourselves.
Also remember if you want to do it, Don't do it on the engine, you'll get metal shavings into the cylinder..
This is so common, I'm surprised some Sparkplug company doesn't make a slightly oversized self tapping sparkplug ????
RON WOODGEARD is offline   Reply With Quote
Old 11-08-2004, 01:48 AM   #6
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Ron, sounds like an idea for a money making invetion
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 11-08-2004, 01:50 AM   #7
cableguy0
if people would pay attention and not use an air ratchet to start spark plugs in the whole this really wouldnt be a problem. not trying to sound like a jerk but i have seen so many heads ruined with all 4 spark plug holes destroyed cuz some jerk was trying to save time and use air tools or just flat out cross threaded the plugs
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-08-2004, 01:56 AM   #8
RON WOODGEARD
CableGuy,
You are right !! But that doesn't fix his friends delima now.
I like to help remedy the situation instead of Chastize the person who did it...I think there has already been a lesson learned...
Old 11-08-2004, 02:05 AM   #9
cableguy0
oh i know ron i didnt mean to sound like i was putting his friend down.chances are the head should be pulled and taken to a machine shop and drilled and helicoiled
Old 11-08-2004, 02:23 AM   #10
Alexis
Member since 2000
Alexis's Avatar
I don't use air tools on any motor, so don't get that idea. He just bought the car about 3 months ago. The problem started when a spark plug was thought to be loose after a rescent tune up, they didn't touch the plugs. We took out the coil pack and found out it was loose. When I pulled it out I found the threads of the block around the threads of the spark plug. When we got a new spark plug it did not match the one we pulled out. We check other spark plug and they all were the same......someone ****ed up when the tuned the car up. Ron I was actually thinking the same thing, i got a nieghbor down the street who runs a machine shop.
After we found out the plugs were not the same we changed all the spark plugs. Well I did......We will see tomorrow.
thank for all the input guys. Cable guy I understand your stance.
Old 11-08-2004, 04:08 AM   #11
68LSS1
68LSS1's Avatar
With the repair kits you just use the tap and install the Helicoil or Sav-a-Thread. No drilling required. There are special thread chasing type tools for spark plugs holes from specialty tool makers. They are not cheap, like $68.00 for the KD brand. There used to be a kit that you could get by thread pitch and came with 4 different reach inserts. The tap had a hex for a socket. You then picked what reach insert you needed, screwed that on the plug then installed them together. Put the piston close to TDC and put a oil soaked paper towel to catch and chips, remove it and blow it out with some air. Pulling that head will be a pain. I want to put a set of the newer PI heads on my '97 Mustang but I'm dreading the dual overhead cam thing. Probably won't be too bad once I get into it but I'll just wait until I blow this engine up.
Also when using aluminum heads, never remove the plugs from a warm/hot engine. Let it cool completely before removing them and use some anti seize when you go back in with the new plugs.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
