Old 11-07-2004, 11:46 PM   #1
tkeduk8r
tkeduk8r's Avatar
what'd you guys use??
what do you guys use to plug the A.I.R. tube holes in your mainifolds??? im actually in the process of a cam swap in a 305 powered caprice, ( i know not a truck but hey, its still a small block ) the guy a t napa told me they dont make a plug for it, but im not sure if he was sayin this cuz it is true, or because there were other customeors in the store and doin anything with smog controls could be reported.. who knows... any suggestions??? can i retap the holes for a pipe plug??? pinch the air tubes off and tack weld them shut and reinstall??? thanks in advance...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 11-07-2004, 11:49 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
on my straight 6 i took the factory ends that thread in and cut the tube out and welded them up and screwed them back in
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-07-2004, 11:51 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
On the 454 that I build for my dually, it seems like I used either 1/4" or 3/8" pipe plugs. Whichever size it was, they fit perfectly. You might pull a rail and compare it to pipe thread.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-08-2004, 01:58 AM   #4
krue
Designated A-hole!
krue's Avatar
Pipe plugs should do youl.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-08-2004, 03:19 AM   #5
1972C10
1972C10's Avatar
GEt some 1/4 NPT Allen Plugs It will look better than plain galvinized plugs But if your lookin cheapest way out Plain black pipe or galvinized plugs.
1972C10 is offline   Reply With Quote
Old 11-08-2004, 01:03 PM   #6
tkeduk8r
tkeduk8r's Avatar
well the NAPA guy said a regular pipe plug wont work... i thought pipe thread was all the same... so a allen 1/4 NPT plug will work then??? cuz i can stop at he parts place on my way home tonight...
--Mike
Old 11-08-2004, 02:13 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The guy at NAPA is wrong.
Buy 8 plugs, 1/4 N.P.T. and screw them in.
I have done it many times.
Old 11-08-2004, 08:25 PM   #8
1972C10
1972C10's Avatar
Some are differnent though But i doubt yours is Im certain its the same manifold as a camaro of same era and ive plugged them off..
My 85 was an odd size that was fine thread metric and i couldnt get a plug for that .. But it's Got Factory Steel Manifold Headers
Old 11-08-2004, 08:43 PM   #9
shortymac83
hmm...
shortymac83's Avatar
I've used pipe plugs on olds 307's for the same reason. HOlds up fine, but don't use any kind of pipe sealer goo or silicone unless you want to hear some whistling, I used the high temp silicone stuff, still melted and made a godawful whistling on a client's car.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 11-08-2004, 08:45 PM   #10
1972C10
1972C10's Avatar
I put motor oil on mine and run them down with an impact No Leaks.
