Old 11-08-2004, 01:48 AM   #1
ocbaud
Garage Queen Material
flip kit and shackle= cnotch??
since my rearend is out, and i've got to take my leafsprings out, i thought i might wanna get some lowering shackles for the truck. would i have to run a cnotch to run these? right now i've got about 4.5" of clearance between the frame and axle and i have never once bottomed out. most big bumps and train tracks and stuff like that i take really slowly(especially with my new wheels, even though i've got 50 series tires)
ocbaud is offline   Reply With Quote
Old 11-08-2004, 03:15 AM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
I can't imagine not having a C-notch w/ a flip kit. Let alone + shackles.....
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-08-2004, 08:39 AM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Shackles will lower it about another 1.25" or so. A c-notch would be mandatory on my list. Only thing though, you should have marked where the axle center line was on the frame before removing it. With it not in there, no way to know where to put the notch.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-08-2004, 09:29 AM   #4
ocbaud
well, to put a notch in i would have had to take the bed off, which i dont wanna do right now, and i cant afford the cnotch right now either, so i guess i wont get teh shackles
Old 11-08-2004, 01:28 PM   #5
loblazer
loblazer's Avatar
Ocbaud, I put a 5" c-notch in my 80 Blazer without taking the body off. You should be able to do yours I would think.
I got a 5 inch I.D. steel schedule 80 pipe. I cut a piece off on the chop saw, the width of the frame. I then cut it in half to make 2 pieces. I made a template for the side pieces and had them cut and drilled by a machine shop from 1/4 plate.
My buddy and I then put the truck up on his hoist, supported the back frame, drilled and mounted the side plate. Then we cut the C out by torch, a little at a time to keep it cool.
Then we welded in the 5" pipe. We put weld all around the pipe when done to add strength.
Added new bump stops in the centre top.
Works good, no cracks, no sagging, no bottoming out.
Doug
loblazer is offline   Reply With Quote
Old 11-08-2004, 03:42 PM   #6
Izzy
Trucker.
Izzy's Avatar
You can do the notch on a 73-current SWB's without pulling the bed.
Izzy is offline   Reply With Quote
Old 11-08-2004, 04:37 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Ditto on what everyone else said. You can do it without pulling the bed, it just makes it easier...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-08-2004, 05:59 PM   #8
SCOTI
SCOTI's Avatar
The flip kit + shackles does need a c-notch but it is possible to drive around w/o one. I still haven't added the c-notch to mine & have been driving it daily now for well over a year.
I can't carry any excess weight though.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-08-2004, 06:19 PM   #9
Captkaos
Captkaos's Avatar
So, you are saying is you have to watch your girlish figure all the time?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-08-2004, 06:27 PM   #10
low 84
low 84's Avatar
depends on what notch you get. you do have to pull the bed when using a western chasis notch, it has bolts that go on top on the frame rail. i'm not sure if the djm and belltech notches are the same way
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 11-08-2004, 06:34 PM   #11
blitz'd
vintage car junkie
blitz'd's Avatar
Doug
If its a 5" pipe cut in half wouldnt that make it a 2.5" notch?
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 11-08-2004, 08:20 PM   #12
SCOTI
SCOTI's Avatar
No . . . . I don't have to worry too much. But if my GF gets in the truck & I mention something along the lines of.... "gee.... it usually doesn't bottom out w/just me in it" . ...... , I'll be sleeping in that no c-notch havin' truck (not that I haven't slept there already for various other reasons).
low 84 depends on what notch you get. you do have to pull the bed when using a western chasis notch, it has bolts that go on top on the frame rail.
Yep, that's right about the Western Chassis c-notch. Because of the right angle curve that sits on top of the frame rail, the bed needs to come off so you can drill the holes. The little 1/4" thick roll that's on the top of the notch is a little stronger than just a 1/4" plate bolted to the side of the frame IMO.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-08-2004, 08:57 PM   #13
low 84
low 84's Avatar
i agree, thats why i used them on mine
'05 1500 Crew Cab
RIP
