Old 11-08-2004, 01:53 AM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Anyone ever converted to hydraulic clutch?
I was looking at a wrecked 89 camaro today thinking the 5 speed tranny would be a nice touch to my truck, has anyone ever converted their truck to use a hydraulic clutch instead of the old mechanical linkage?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 11-08-2004, 03:23 AM   #2
1972C10
1972C10's Avatar
I put a Camaro T5 into a 68 used a 85-87 3/4-1 ton truck master cylinder had to submodify the rod and shorten it but other than that pretty simple
If you do get a camaro trans keep in mind your gonna have to do some riggin on the line since they use a plastic line
1972C10 is offline   Reply With Quote
Old 11-08-2004, 09:09 AM   #3
Huck
Huck's Avatar
I put a 5 speed out of a 96 1/2 ton pickup into my 72. The hyd cyl mounted behind the brake booster but ---booster bracket required shimming---had to rig clutch linkage to work ----had to cut new hole in floor hump----had to have drive shaft length adjusted----have to run without speedo do to the late model elec sensed pickup on trans. Make sure you allow for shifter position as some are real close to seat--depending. Mine is way up towards heater vent. Most hyd clutches have a real easy pedal---mine is real stiff--don't know why--?!
Huck is offline   Reply With Quote
