Old 11-08-2004, 04:35 AM   #1
ChrisF
62 Suspension conversion to newer 71 and up disk
Can a newer suspension bolt up to the old torshion bar style 60-62 truck front end... I am asking because I have a 1962 and would like to go disk and Airbag with out spending 900 bucks on a aftermarket disk kit , and still not be able to go with airbags...
Chris
ChrisF is offline   Reply With Quote
Old 11-08-2004, 06:30 AM   #2
BADBOY66
born to drive a CHEVY
disc
should bolt right up to old holes
BADBOY66 is offline   Reply With Quote
Old 11-08-2004, 08:51 PM   #3
zenish
you can get drop spindles for around 200.00 and then use junkyard rotors and callipers.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 11-09-2004, 07:48 AM   #4
ChrisF
Up to what year will work?
Chris
Old 11-09-2004, 09:00 PM   #5
zenish
buy the spindles for your year truck,then use the brake parts from a 1973-87.ask the spindle maker what fits.
1964 c10 short step
1962 econoline van
1989 rs camaro
1975 goldwing
Old 11-12-2004, 01:48 AM   #6
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
If you're going to replace the front suspension, make sure you pull it out as a whole unit, cause the torsion bars are under alot of tension. I'd use a '63-'84 gm front clip, and 4 new holes will be needed to be drilled. You'll have to use the tie rod linkage & idler arm set up off of the same donor truck. Also when swapping out the torsion crosmember, you'll loose the front engine mount for the 235 since it's riveted to the saddle. If you plan on keepiong the 235 in the '62 for awhile, i'd weld it to the front of the new saddle.
I plan on doing this swap eventually too, after I swap the 235 I6/3 speed for a 350/350 setup.
Or if you're wanting to make your truck a swb, find a donor swb '63-72 GM truck frame, or even better, a '71-72 swb chassis, and it wil have 5 lugs with disc brakes.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
