Resident Young Old Dude !
Parts for Sale or Maybe Trade...
#1. Step side fender, Original drivers side without cutout, Very Nice !
$300.00 Shipped #2. Step side fender Original passenger side, Very Nice ! $200.00 shipped #3. A/C dash unmolested $175.00 Shipped #4. 73-to? Short step bed sides Very nice ! $200.00 each side, Local Pickup only #5. Auto. Column, and linkage $120.00 shipped #6. ” broken” billet grill, good 67 split grill billet project SOLD !!!! Traded to TXFirefighter!!!! $60.00 shipped #7. Step side tailgate with louvers $100.00 shipped. #8. 67-72 Step side Steps Very Nice ! Right and left. $100.00 shipped #9. 67-72 Step side step brackets Right and left. $60.00 shipped #10. 67-72 Step side cross braces $25.00 each Shipped #11. Removed from sales list.... #12. Lund Sun visor SOLD, Traded to TX Firefighter.... $65.00 shipped #13. Early Corvette Front engine mount $90.00 shipped #14. Holley Spread Bore Carb. Needs rebuilt $130.00 Shipped #15 Wood bed , Paintable Steel strips for short step side bed. these are “new” in box $70.00 shipped #16 67-72 Step side drivers fender w/out cutout needs some work $200.00 shipped #17 Original Chevrolet Step side Tailgate $100.00 shipped #18 67-72 short step bedsides $100.00 each Local pickup only! # 19 Saginaw 4 Speed manual Tranny. Excellent inside, Tight input shaft bearing. $160.00 shipped #20 Aluminum Flywheel, ( stick) Good shape $60.00 shipped #21 Pressure plate and Clutch disc, Never used but Rusty. ( got left outside ) $35.00 shipped #22 A couple of Passenger side Step side fenders, Varying in condition $75.00 to $125.00 + Packing & shipping #23 Step side Taillights, backup lights W/lenses, wiring and Brackets $65.00 shipped #24 Dodge "Original" early 70's Flip cap Fuel filler complete $90.00 Shipped #25 Paintable Steel strips for short step side wood bed. these are “new” in box $70.00 shipped I can send or post pictures of all items. But remember I do work an actual job, Over 9 hour days, So don't get in a big hurry.. _________________________________________________________________ Items I may be interested in for Trade. Radio Control Items ? 2-10" JL subwoofers Dual voice coil Two Higher End Car audio Amps. Front Aftermarket chrome Bumper with the driving lights. New or excellent condition! Rear fleet side Chrome sport bumper. New or excellent condition ! Rear fleet side bumper brackets. Hidden hitch A set of doors in good shape already shaved. A very good set of rear trailing arms, with frame brackets and u-bolts for rear end, adjustable pan hard bar. A 1-1/8" or 1-1/4" Front sway bar with mounting brackets. Rear Sway bar and Brackets for both, Leaf spring rear and coil spring rear. Caddy “Eldorado” Thin long ones, Tail lights, Complete... Two K&N Velocity stack air Cleaners.. High End “in line” Tunnel Ram linkage. Billet aluminum remote hood opening linkage. New High lift S.B. cam and lifters Aluminum Roller rockers. Last edited by RON WOODGEARD; 11-10-2004 at 12:24 AM. |
I have a lot of PMs on this stuff, PLEASE,,, At least post here you have PM'd me, I don't want someone thinking I'm selling out from under them..
Also, The Carb, is a 650 Spreadbore, Model 4165 Single inlet, Double Pump, Mechanical Secondaries, with Choke. needs Revamped, ( Boiled out, new gaskets, Etc. It's been sitting for 12 years) Thanks Ron In addition, I'm in Nevada, South of Reno about 75 Miles.... Last edited by RON WOODGEARD; 11-08-2004 at 09:32 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Ron, #12, the aftermarket visor, do you have pictures or details?
#4 | |
![]() ![]() Last edited by RON WOODGEARD; 11-09-2004 at 07:20 AM. |
Ron, this may seem obvious, but it is for a 67-72 for sure right?
I have bunches of RC car stuff to trade towards parts.
#6 | |
pm sent
![]() Join Date: Aug 2001
![]() RON... I HAVE A PAIR OF SHAVED RUSTFREE 72 PICKUP DOORS. EITHER CALL OR P.M. ME IF YOU'RE INTERESTED. ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
What was I thinking??
Ron
#11 Is the slider tinted? and what kind of shape is it? Thanks Cethern
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
#10 | |
#11 | |
I'm holding the Visor and Billet Grille for Txfirefighter..
#13 |
Here's a couple of pictures of the Carb.. This is a heck of a Performance Carb.
![]() ![]() ![]() ![]() Last edited by RON WOODGEARD; 11-09-2004 at 05:03 AM. |
#14 |
Active Member
![]() Join Date: Aug 2004
I'm very interested in the saginaw 4spd. What's the difference between it and a Muncie?
69 C10 LWB Project 47 Cushman Scooter Project It is better to have loved and lost than to live with a psycho all your life. ![]() ![]() |
#15 | |
Some Muncies are heftier, others are about the same.. This tranny will go well behind everything but the strongest built motors. and the roughest of users.... any tranny can be busted with Abuse.. I am running right at 400 H.P ( guestimation) and I bought it to run behind it.. But I'm not Lead Footed any longer. I ran one behind a stock 375 HP 396 ( I had headers and an Aftermarket Manifold and Carb. 4:11 Gears W/posi. ) way back when.... I never had a problem with it. And I wasn't real easy on it. ![]() This tranny is tight in the gears, and has No Chipped or worn teeth.... It also has a tight input shaft bearing.. It shows no sign of abuse.. Just outside case dirt.... Also, There is 2 different gear Ratios for the G.M. Saginaw 1st:3.11, 2nd:2.20,3rd1.47, 4th 1.00--- The other is, 1st:2.85, 2nd:2.02, 3rd:1.35, 4th:1.00 I don't remember which this one is, If it matters, I can figure it out... I was going to go 4-spd. in mine but since have decided to stay with my 350 Turbo, and a Stall Convertor. Unless later I go to a 5 or 6 Speed... Last edited by RON WOODGEARD; 11-09-2004 at 07:37 AM. |
#16 |
Ron, I'm interested in more information about #7, the louvered step side tailgate. Pics and any other info I might need to know about.. here or to *****************@yahoo.com
Thanks, Don |
#17 | |
![]() Last edited by RON WOODGEARD; 11-09-2004 at 07:15 AM. |
#18 |
Ron, let me ask around about someone that can sand/powder blast around here. I just moved here 2 months ago, and still don't know anyone... been working way too many hours.
Anyone interested before I respond back here is more than welcome to first dibs. Thanks, Don |
#19 |
Billet grille for TXFIREFIGHTER....
#20 | |
Cethern, I got the slider out tonight and cleaned it off, It has some small sand storm type pits in the glass.. I wouldn't feel good about selling to you.. Sorry. I'll remove it from my list... Ron |
#21 |
PM sent...
#22 |
Here's a couple of pictures as requested of the rear step fenders.
