Old 11-08-2004, 03:58 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Lower radiator hose fitment problem
Because of the body lift I had to do, I am having trouble getting a radiator hose to fit from the water pump to the lower radiator outlet.
As you can see, I need a hose with a pretty radical bend at the pump.
Spent some time at the auto parts store and nothing looked like it would work off their shelf.
I know there are aftermarket flexible hoses - anyone know if they can do bends such as what I am needing?
Here is a view looking straight towards the engine
And here is a view looking from the top of the radiator down.
The hose I have cannot make the bend without starting to collapse.
Also considered using a metal sleeve to put a couple hoses together but remembered a post recommending only using a certain type of metal tubing for the sleeve - anyone have a recommendation if I go this route?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-08-2004, 04:30 PM   #2
meathead95
computer illiterate
meathead95's Avatar
get a flexible hose from auto zone thats what i did on my v8 s10 you can bend the sh!t out of them without collapsing it
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-08-2004, 04:43 PM   #3
sdmahr
sdmahr's Avatar
I also use the flexible lower hose. It has a coil spring inside to keep it from collapsing. Never had any problems. From the looks of what you are trying to do it should work fine.
sdmahr is offline   Reply With Quote
Old 11-08-2004, 05:49 PM   #4
dubie
dubie's Avatar
I had to buy a lower hose for a small block 4x4 from 72 to get it to fit right with my engine set back in the I6 posiiton. It has the exact kind of bend to it as yours
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 11-08-2004, 06:04 PM   #5
70c10
67-72 Addict!
70c10's Avatar
I seem to remember having to use a 71' hose.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-08-2004, 06:06 PM   #6
purple gas
on my 67 , I put in a newer 305, with a longer pump, and the lower rad outlet was straight, not angled like the original. After much frustration and many many trips to the parts guy , I eneded up with a hose for a mid 70's truck, It is a Dayco #70735, length code E. when I installed it it bent & collapsed. I "borrowed" a hose off a buddies in progress truck, and it was the same, only shorter. So I trimmed a bit off the ends and it fits no problem. Just remember, if you cut 'em, you own 'em. I've also heard flexy hoses put a lot of stress on your rad outlet connections. Hope this helps.
purple gas is offline   Reply With Quote
Old 11-08-2004, 08:46 PM   #7
crazy longhorn
Fabricate till you "puke"
Yukon, the angle on the waterpump is a lot like the later style(long) sb pump. my thoughts are along the same lines as Purple Gas.....use a 73 up style hose. You will need a straight neck in the bottom of the radiator to fit the hose tho..... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-08-2004, 08:51 PM   #8
3 on the tree
Use a short sstraight piece off the water pump-get a pre bent piece of exhaust pipe from a muffler shop to connect the two hoses-many clamps, but no collapsed bends!
3 on the tree is offline   Reply With Quote
Old 11-08-2004, 09:00 PM   #9
roadking
like someone has already mentioned try a 73 to 77 hose, you get the extra bend for the frame. worked for me.
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 11-08-2004, 10:33 PM   #10
gr8scott51
gr8scott51's Avatar
I used a Gates hose, part number 20843.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-09-2004, 12:23 AM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
After work, but before some of the rest of the above posts, I stopped at another parts store and did some looking through their selection. Still nothing looked like it would work, the body lift is causing the majority of the problem.
Ended up buying another hose with a 90 degree bend and splicing the two hoses together is perfect.
My stock upper radiator hose used the pipe in the middle but I remember a post or two where people said not to use just exhaust pipe for a splice. Some stated, like 3 on the tree, that you could use exhaust pipe. I know the inside of the stock pipe that was in my upper radiator hose had a bit of corrosion in it.
Should I try to get a short piece of stainless to use for the splice, it just needs to be a straight piece, no bends - or is regular exhaust fine? I am using an aluminum water pump if that plays into what type of pipe I should use.
Old 11-09-2004, 12:53 AM   #12
Gator70
Gator70's Avatar
The pipe that is stock on the upper hose of my K15 350cid is just aluminized pipe(exhaust tubing) I still have the original pipe in there and its just starting to show some signs of wear. Thats 34 years old. I have now opted to run a molded hose and had to sort through bout a dozen before I got one to fit, I think that the description was for a D****E but I wont tell anyone.
The lower hose that I finally searched for looks like it may also work in your spot. I can look up the no when I hit the shop tomm if you like. If your local parts store carries dayco I can also cross the Goodyear nos to Dayco.
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
Gator70 is offline   Reply With Quote
Old 11-09-2004, 12:54 AM   #13
'71c204x4454
'71k204x4454
I did the stare at the wall with all the hoses for my bb install. Ended up with a gates 20694. I don't know if I had to cut any off but by your pictures it looks like it will work for you. I think I'd find one that fits correctly that way you won't have to worry about splicers or any other problems.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
Old 11-09-2004, 10:27 AM   #14
Yukon Jack
Post Whore
Yukon Jack's Avatar
Gator70 - if you get the chance to post the number and the cross if that is no problem for you. I will take all of the above numbers and do some more looking and if that doesn't work, I will go with the spliced one.
Thanks, this board always comes through!
Old 11-09-2004, 12:08 PM   #15
Gator70
Gator70's Avatar
Yukon Jack, are the ends you need 1 3/4 for the rad and pump?? Does your rad outlet come straight out or angle up. Im workin on the x-reference, lost our book.
Old 11-09-2004, 12:17 PM   #16
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yep, both ends are 1 3/4". The rad outlet angles up. Here is a pic I took of the two hoses that when cut and spliced together, work perfect. Thanks.
Old 11-09-2004, 12:47 PM   #17
Gator70
Gator70's Avatar
Hey Yukon Jack, looking at your picture Goodyear no. 60709 should be the fit. Sorry cant find the x-ref for dayco. even their website has the interchance blanked out.
Hope this helps some
The 60709 measures 9 in from the outlet to the bend, from the same axis of the bend it then measures 12 in to the wp conn. toward the wp connection it makes a 22 deg?? bend upward. sorry dont have a digi cam to send you a pic of this hose.
Good luck, if I can be of anymore help just let me know.
Old 11-09-2004, 01:22 PM   #18
Yukon Jack
Post Whore
Yukon Jack's Avatar
Thanks, I will check out that one if I can find it, any idea of what vehicle/engine setup it is intended for?
Old 11-09-2004, 03:08 PM   #19
Gator70
Gator70's Avatar
The hose matches up to 95/96 Ford p/u with 4.9 L6 lower hose (alternate) the other hose that is listed matches that Dayco 70664 that you have. I looked it up in a dayco cat. and the lower hose only has one listed a 71873. Goodyear shows the 2 hoses, Dayco only showed one.
