Old 11-08-2004, 05:12 PM   #1
85chevy
rear end ratio
Is there any way to tell what the gear ratio is in the rear end of my truck without having to take the cover off? The dealership said they do not have records that far back. Also, where can I find a good set of gears for a decent price?
85chevy is offline   Reply With Quote
Old 11-08-2004, 05:37 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My '86 has the gear ratio on the sticker in the glovebox. Maybe yours does too. Of course, on these old trucks, you never know what has been changed from original.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-08-2004, 06:07 PM   #3
mckpaul
mckpaul's Avatar
I've seen and tried a couple of ways. One way, jack up one back wheel and rotate it forward exactly two rotations watching and counting the turns of the drive shaft. Mine is a 2.73 rear end, the drive shaft turned 2 3/4 turns when I turned the wheel two times. You can take a piece of string about three feet long and tape the end of it to the bottom of the drive shaft and then turn the wheel, and then see how many wraps of string you have on the shaft. I even taped the sting to the drive shaft and marked the tire where it was centered on the pavement, then started th truck and moved the truck forward ONE exact turn of the tire until the mark was on the pavement again, and then turned it off and got under it and counted the wraps of string. NOTE - When you move the vehicle and BOTH wheels move forward one turn (as in when you are actually rolling or driving) you use ONE revolution of the wheel. You only use the TWO revolution method when you have one wheel jacked up and the other is stationary on the ground.
Paul
1984 Chevy C-10
*LWB/305*
mckpaul is offline   Reply With Quote
Old 11-08-2004, 09:53 PM   #4
85chevy
Thanks alot. I have a sticker on the glove box, but the glove box lid is not the original one.
Old 11-09-2004, 12:54 AM   #5
TIMSPEED
TIMSPEED's Avatar
You can check the number stamped into the axle tube. You might need to use a brillo pad to clean the axle tube off to see it though. If you get it, it'll be a 3-digit code "xxx". Post it here, and someone can tell you what gears you have. (That's how I found out I had 3.42's, stock)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-09-2004, 09:54 AM   #6
gn4u2c
gn4u2c's Avatar
Maybe its a dog because you have a 305 ?? Just kidding ! heck if you are close stop in I will pull the cover and tell you whats in there.
gn4u2c is offline   Reply With Quote
Old 11-09-2004, 02:08 PM   #7
mckpaul
mckpaul's Avatar
Originally Posted by gn4u2c
Maybe its a dog because you have a 305 ?? ...
Hey, hey! I resemble that comment! Actually the only reference to a 305 on this thread is in my signature. But you're right, a 305 with a 2.73 is pretty much a dog in the short haul. On the other hand, it's great for normal everyday driving.
I have a sticker in my golve box, but it doesn't say anything about the rear end, only talks about bed measurements for a camper and load limits.
Paul
1984 Chevy C-10
*LWB/305*
Old 11-09-2004, 02:47 PM   #8
oldraven
oldraven's Avatar
I'm wondering the same thing. Except mine's too short. With the 383, the damn thing shifts into third at 60kph. (37mph) Far too early. Man do I need a tach.
'86 C10 regular cab, 383 on propane www.cardomain.com/id/doasa
'87 TurboCoupe 2.3Turbo intercooled 5-spd
www.cardomain.com/id/oldraven
'93 Jeep Grand Cherokee 4.0L
oldraven is offline   Reply With Quote
Old 11-09-2004, 05:58 PM   #9
cliffsta
Stepsides RULE
cliffsta's Avatar
LMFAO @ mckpaul. Beat this: I got 2.56 gears in mine with a 305! Now THAT'S a dog off the line, but i love it for daily driving, since that's what i do. I can hit like 45 or 50 in first
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 11-09-2004, 06:35 PM   #10
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
This thread is located in FAQs
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
