Old 11-08-2004, 10:10 PM   #1
Fred T
Cantankerous Geezer
Fred T's Avatar
Bracket help
I need help, I don't have much hair left to pull out. Trying to put my 69 back together. It had a cobbled up mess for front brackets on the engine, along with a short water pump. I went back to a long pump and am stumped as to what to do for brackets. Switching to newer alternator, which should be on the left (driver's side). Will also be putting on a/c, am figuring a small compressor. Truck also has power steering.
What would be a good route to go for brackets. Edelbrock heads with drilled and tapped holes and headers. Any suggestions, I'm out of ideas unless I start building my own, and that will take too long.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-08-2004, 10:13 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've never seen any dvr side alt mounting with a long water pump...only with the short pump (as original)
Old 11-08-2004, 10:22 PM   #3
Super Duck
Chevy Nuttttt
Super Duck's Avatar
local scrap yards
local scrap yards will have what you need cheep. try to get the ones off a late 80s to get the surpentean belt for the alt to water pump
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 11-08-2004, 10:44 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Fred, 69-72 trucks used short pump sets originally.
73 up through mid 80s trucks will have long pump setups. But, like Andy said, the alternator will be on the passenger side that way. If you want driver's side alternator, you're going to need to use short pump setup.
Old 11-08-2004, 11:36 PM   #5
Cethern
What was I thinking??
Cethern's Avatar
If you not going with OEM I would look at Alan Grove and what they have for Brackets.
http://www.alangrovecomponents.com/index.htm
They have more than a few neat brackets.
Cethern
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
