Old 11-08-2004, 11:17 PM   #1
wolfthing2000
Question Ring gear count for 4:56
Does anyone happen to know the ring gear tooth count for a 4:56 ratio rear axle for the 69 3/4 ton corporate style (Eaton?) that has the 3rd member drop out ( quick change style carrier)......??????
Thanks,
Dave
wolfthing2000 is offline   Reply With Quote
Old 11-08-2004, 11:31 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Should be 41-9
BLAZERMAN is offline   Reply With Quote
Old 11-08-2004, 11:32 PM   #3
BLAZERMAN
BLAZERMAN's Avatar
Sorry, thats 41 teeth on ring gear and 9 on pinion.
Old 11-08-2004, 11:47 PM   #4
wolfthing2000
Thanks for the numbers. Makes it so much easier.
Dave
Old 11-09-2004, 02:08 AM   #5
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
41 / by 9 is 4.555555555555555555555556
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 11-18-2004, 01:07 AM   #6
wolfthing2000
For the record on this board::: The front axle on the 69 says 4.56 and when pulling out the rear 3rd member I have discovered that the ring gear is a 32 and the pinion is a 7 for a 4.57 ratio which is slightly lower gear ratio than the 4.56 making the front tires pull ahead slightly faster theoreticaly keeping them in front or the leader on slick surfaces Thus the truck stays in a straight ahead position rather than the back end coming around in front.
However I have proven beyond any doubt with my CJ5 Jeep with the same gear set ups that the rear end will pass the front end up with little more than a blip of the throttle at the wrong time!!!! Believe me it can be quite entertaining whether done intentionaly or by accident!!
Passengers love it too!!!!!!!!!!!!!!
Dave
Old 11-18-2004, 01:13 AM   #7
1969 GMC
1969 GMC's Avatar
Yeah the Eatons are weird like that. 4.11s, not 4.10s...4.57s, not 4.56s...5.14s, not 5.13s. My dana 60 will get 5.13 gears up front. My dad thought it was really weird that GM did this from the factory, but most people say that such a small difference wont even be noticed.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-18-2004, 09:45 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I've heard of this before, never checked it out, and in theory it makes sense. But if the front is geared slightly lower, it will turn the tires more slowly than the rears, not faster. Hmmmm....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-18-2004, 11:59 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I think to have any noticable difference you'd have to have like 3.73s up front and 4.11s in the back with the same size tires. There was a truck like this in a magazine and it was strickly for mud bogging.
The reason for the slight variations between front and rears in production vehicles is probably more a function of design constraints between the different manufacturers. Really between 4.09 and 4.10 the difference is like 0.25% hardly noticable. You could have more variation between the tires than that. The only vehicle I had that the front and rears matched was a scout II with front and rear Dana44s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
