11-09-2004, 12:31 AM | #1 |
Tilt vs. Non-Tilt questions....
Looking @ swapping my column. I have the manual column right now and bought a non-tilt column to replace it with. Currently using a B&M to shift also have 700r4 tranny. My non-tilt column needs cleaned up, paint and what not.
Looking at pics of the van and truck tilts I see the bottom of the column has no shifter dogs/stops like my non-tilt has. Are the tilt column dogs/stops internall in the housing? or do they just use the tranny detents to keep it in place? My brother has a line on a van tilt and I thought about using it. Also thought about using my non-tilt and modifying it for further travel for the 700r4 detents. Is this necessary or should I just bolt either in and adjust for fit/shift?? John
Locab36 1936 low cab 1/2 ton 1956 BMW R25/3 1968 Moto Guzzi V7 1969 BMW R100/2 1986 Silverado SWB 2007 Harley FLHTP 2011 GMC SWB 4x4 Z71 http://www.flickr.com/photos/locab36...7623329816080/ |
11-09-2004, 12:47 AM | #2 |
its all about the +6 inches
You'll need to get details...maybe a search, but some one said something about moving the pivot point for the shift lever on the tranny and being able to get all gears on an OD set up.
11-09-2004, 08:21 AM | #3 |
Watch out for your cornhole !
The dogs are internal. When you install the tilt, it will still shift properly, that is, it will still have detents.
11-11-2004, 04:33 AM | #4 |
Stepsides Are Bedder
Yep, it's right off the shift lever. Just so happens I have my van tilt apart for detailing. Here's a pic...
11-11-2004, 11:43 AM | #5 |
Thanks,
It looks like with a little die grinder work I could get some more movement for the 700r4 throw needed. My brother scraps old cars on the side and he is on the look out for a van tilt for me. John
