Life, Be In It.....
![]() Join Date: Oct 2003
I have seen the parts, and read posts from people doing it. But why would you relocate the front shock? Got any pics?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
Wouldn't. The shock relocators I've seen (and used) are all for the rear.
Silence is golden, duct tape is silver. - Scott |
Life, Be In It.....
Here is a picture of the relocation. It is done to reposition the shock to the correct, >15 degree angle. Smoothes out the ride on slammed trucks a bit. Hope this helps.
USMC "Pray for peace, train for war" (The Beast) 68SWB Stepside Original 325hp/327 3:73 Posi Lowered 3.5/4.5 ![]() |
Life, Be In It.....
Just the information I was looking for, good pic too. Thanks
I saw that thread. It seems that only bagged fronts use them but i was wondering what amount of spring drop would require the front shocks to be relocated?
If you only have springs/spindles it would be pointless to relocate the shocks, these are for bagged applications only.
#9 | |
I have a 2 1/2" set of drop spindles and 1" drop springs all from Classic Performance installed on the front of my 68 and before these relocators were installed the shock angle was at a 20 degree angle and after, they were back in specs at 10. Now at the same time I also rebuilt the entire front suspension joints, arms, and rods. Maybe that also had something to do with it. I was the rock that started the original post on these a month ago. The board memebers really helped me on this one. Thanks to all.
Life, Be In It.....
Well, It sounds like I need to purchase some shock relocators, since I plan on putting air bags on my truck. Thanks all for the info.
#12 | |
#13 |
Plus the fact that GM's front shock mount design was not very good. How many of you have replaced your front shocks and found that the mounting hole for the shock stud was ovaled out? Something with that much leverage on it should be attached on both sides.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#14 |
Lovin' Life in Miss.!
Was following some links and found this old thread. What is the proper way to fix an ovaled out shock stud hole?
Rich
The truck... you hear that? No really, you did hear that?!!! |
#15 |
![]() Join Date: Mar 2000
Personally I use a washer on both sides of the frame and tack weld the outside washer to the frame. I have one done this way on my truck that has seen over 10 years of daily use and it's till perfect.
Saskatoon, Saskatchewan Canada |
