Old 11-09-2004, 01:05 AM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
can i get AT linkage pics please?
im gonna be putting my TH350 in soon and need to know how everything hooks up...my main linkage that comes down from the column etc is on the outside of the frame...is it supposed to be on the inside? or is there another piece that extends it or? pictures would be GREATLY appreciated.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 11-09-2004, 06:30 AM   #2
Custom_C5
How much for it? got any pics?
Custom_C5 is offline   Reply With Quote
Old 11-09-2004, 08:12 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, it's supposed to be inside the frame rail.
If you don't have a picture when I get home, I'll snap one for you and post it.
Old 11-09-2004, 12:35 PM   #4
67ChevyC10Stepside
ok thank you...
Old 11-09-2004, 11:03 PM   #5
Tx Firefighter
here a couple of pics...
Old 11-09-2004, 11:16 PM   #6
67ChevyC10Stepside
hmm....can i get a pic of it installed on a vehicle? the linkage is on the outside of my frame right now...i have the piece that bolts to the frame...but i dont think i have the spring off it....and i dont know that i have the trans piece or the piece between them...will the ones off an 86 chevy work? i have that parts truck. it looks like if the linkage goes on the right side of the frame my headers will hit it....and he LAST thing i need right now is to have to buy headers
Old 11-10-2004, 12:07 AM   #7
Tx Firefighter
86 won't work, it's different.
The linkage goes between the frame and the transmission. It does not go outside the framerails. Your headers should clear it all.
Old 11-10-2004, 12:12 AM   #8
67ChevyC10Stepside
where can i get the other pieces i need? it's a TH350 BTW.
Old 11-10-2004, 01:40 AM   #9
1972C10
1972C10's Avatar
Ive got the entire setup if you cant locate one It even has the pivot bracket that attaches on the frame.
1972C10 is offline   Reply With Quote
Old 11-10-2004, 01:41 AM   #10
67ChevyC10Stepside
how much for just the 3 pieces shown in his pics? i have it from the trans down...
Old 11-10-2004, 01:41 AM   #11
67ChevyC10Stepside
column down i mean
Old 11-10-2004, 01:45 AM   #12
1972C10
1972C10's Avatar
Ill take pics and inspect their condition before i give a price They came off my 72 i converted to a rachet shifter and no longer needed any of them but stashed them away for future use Ill get some pics tommorow evening.
Old 11-10-2004, 01:46 AM   #13
67ChevyC10Stepside
ok thank you. im still wanting some heat shrink BTW
Old 11-10-2004, 07:40 AM   #14
MOTHERTRUCKERS
I have new stainless trans linkage on ebay and in my catalog for 67-72 trucks.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 11-10-2004, 09:43 AM   #15
1-PU70
1-PU70's Avatar
TX Firefighter not to be a PINA but after looking at your pics I went and looked at mine. I have the spring and clip that yours doesnt have and the spring you have I dont have. I then looked in the service manual and it showes a pic like mine. No spring like yours.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 11-10-2004, 10:20 AM   #16
Tx Firefighter
There's something to that.
See, I spent plenty of years working for the Postal Service as a mechanic on mail trucks before I changed careers. Mail trucks have a similar linkage and they use the bigger spring, so I added one to my linkage. I think it works as well as, or better than, the original type, like your truck must still have.
Frankly, we threw away buckets of those springs, so I was able to source them free of charge, so I used one on the truck.
I tried to post the disclaimer in red on that second picture that it's not factory correct.
You might notice, the linkage isn't totally stock either. I spent a Saturday afternoon completely rebuilding the pieces. I welded up the holes and slack and remachined everything so it would fit perfectly. Then, I replaced the "pin" on the frame bracket with a new, harder steel, pin that shouldn't wear as much as the original.
I am obsessive compulsive about such things. I have never knowlingly said the words "good enough" in my life referring to any of my work. My old orange truck had sealed ball bearings supporting a billet steel linkage. It worked smooth.
Old 11-10-2004, 02:20 PM   #17
RON WOODGEARD
Resident Young Old Dude !
I would have liked to see that!!!
I was going to comment on the cleanliness of your linkage, just to give you a hard time, Now I know why.. Da## Nice job Kevin... I would rather have something that I know will stay on then factory correct.. But then again,, Look at my truck..
RON WOODGEARD is offline   Reply With Quote
