Old 11-09-2004, 11:00 AM   #1
Solver
Solver's Avatar
Bucket seat upholstry ?
I am getting ready to put new covers on my buckets but ran into a question that someone who has done this can answer.
The covers have the usual wires around perimeter for the hog rings to mount but these covers also have an inner set of wires to pull covers into seat groves.
these are run through the foam and tied to wires under seat on originals. If you have done these seats what was your process for hooking up these wires. Or did you skip this part.
I have done bench seats but this is a new thing for buckets
Thanks Solver
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 11-09-2004, 12:14 PM   #2
GSFMECH
On the road
GSFMECH's Avatar
I recently did mine. You have to install all of the wires as you mentioned. Mine had wire clips that run through the foam. I hooked these up first before I started hog ringing it. If you leave them out the contour of the seat won't be right because they pull the upholstery down tight against the foam and that helps form the contour of the seat. If I remember correctly there were either different length wire clips or the amount you used depending on the location to get the covers to hug the seat properly. Anyway once you start hooking them up you will see what I mean and you can adjust them to make the seat look right. Main thing is to get it right BEFORE you start hog ringing it on.
Mike
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
