Still drivin' a Rat Rod
Yet another tilt question
OK I pull my tilt yesterday,and it does have the horseshoe connector.I have called every parts store in the area and can't get an adapter.Sooooo can I swap the turn signal switches,and make it work that way?
They suggest splicing the wires,which I really would like to NOT do except as a last resort.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Did you try your GM dealer? I got mine there, but several years ago. I also noticed them recently on ebay.
Saw a used 1 on ebay earlier for 5 bucks....
Gm Part # 1894851
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I guess I don't understand your question because the adapter converts flat to horseshoe. If your column is already horseshoe you shouldn't need an adapter to plug into your wire harness
look for them at scrap yard under the non tilts i found quite a few of them when looking for my tilt. just cut and splice. they used them quite a bit in production i guess.
![]() Join Date: Jul 2001
Sent you a PM.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Stepsides Are Bedder
You can use a small, flat screwdriver or a straight bobby pin and release the wire/terminal from the plastic connector. Insert it between the terminal and the plastic. Push it out the back and re-install it in the other connector. It is harder to describe than it is to do, so if you have an old one bust up the plastic and you will see how the factory assembles them. Nothing to it.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Neon gave you the part number. Last one I bought was like 5 or 6 bucks out the door, with tax included, at the dealership.
