Old 11-09-2004, 02:49 PM   #1
KEH
Better late than never
KEH's Avatar
No High Beam Headlights
When I click my "brights on" my headlights turn off. I replaced my dimmer switch, but that did not fix it. I had just replaced my alternator, but the problem existed just prior to the replacement too.
What could it be?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 11-09-2004, 02:57 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
2 suggestions:
Clean connectors on both harness and headlight bulbs and/or fiddle with them.
Replace your headlights.
Admittedly having the same sympton on both sides at the same time seems rather odd but it's worth a shot.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-09-2004, 02:59 PM   #3
sdkid
Don't take this wrong, but it is possible that both hi-beams of your headlamps are burned out. I have seen it before here at work. Check the power at the headlamp bulb connector and see if it has voltage when on high.
sdkid is offline   Reply With Quote
Old 11-09-2004, 03:07 PM   #4
GMC AMI
GMC AMI's Avatar
Smile Start with the simple things!
I always try the simplest solutions first if unsure. You would be surprised how often it is just that! Great advise MR. Stock ( aka Jeff )!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 11-09-2004, 03:23 PM   #5
KEH
KEH's Avatar
Thanks for the suggestions. All worked well until my alternator went out. Maybe it did blow the high beam elements. I will check it out.
Old 11-09-2004, 09:16 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Pull the plug on the dimmer switch and look in the harness plug for dirt corrosion or melted wires.
That's all I have to add to whats already been said.
