Old 11-09-2004, 06:26 PM   #1
1-PU70
1-PU70's Avatar
HEI Problem
The tack side of the HEI is hot with the key on. I dont think this is right. If there is something wrong would it be the module? AM I missing something?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 11-09-2004, 11:01 PM   #2
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
i think it should be hot...there is power going to it when the key is on for the hole system to work....and it sends power to the tach to tell it to zero....then the pulses make the tach work.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 11-09-2004, 11:21 PM   #3
1-PU70
1-PU70's Avatar
So its hot with the key on and then after it starts in not?
Old 11-09-2004, 11:38 PM   #4
67ChevyC10Stepside
i think it's solid hot and pulses when running...hook a tach wire to the terminal start the motor and hold the end of the wire...you will feel the pulses.
Old 11-10-2004, 02:03 AM   #5
Hooter
My other Love
Hooter's Avatar
plus the power coming out of the tach side of the coil is AC not DC so it will give a funny DC reading, But AC you will notice the voltage stay the same at any given RPM
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
