Old 11-09-2004, 11:32 PM   #1
wolfthing2000
Axle shafts and 3/4 & 1ton
I am in the process of finding a 3rd member 4;56 ratio for a 69 K 20 rear axle.. That is the corporate axle dropout style( Eaton?). I have been told to look out for the spline count for the axle shafts as they differ for 3/4 and 1 tons.. The guy told me to check hex size on the axle flange bolts:::::::::: 3/4 inch ( what I have on the K-20 which to my knowledge came with the truck from factory) indicates a 1 ton. In other words it takes a 3/4 socket or wrench to remove the bolts. But he says the 3/4 ton axle has 5/8 bolts and a different spline count????
What is there to this?? Any fact here or just backyard talk??
I will pull an axle before I head to the salvage yard to be sure.
Thanks,
Dave
wolfthing2000 is offline   Reply With Quote
Old 11-09-2004, 11:43 PM   #2
1969 GMC
1969 GMC's Avatar
The spline count is the same. Not sure about the nut size.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-10-2004, 01:07 PM   #3
wolfthing2000
Does it matter what years?? ie: 52, 57,68 69, are all the same????
Old 11-10-2004, 03:30 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Different years have different axle lengths. There is also some variation on length between the 3/4 & 1 ton. If you have the standard 10 bolt, non-posi what you need is the pumpkin out of a 64-72 3/4 or 1 ton. There was not a ratio higher than 4.56 before '64. About all you will find for higher gears is the 4.10, and they are getting scarce. I have heard of one guy on the stovebolt board finding a 3.73 out of a blazer, but that's it.
If you want better gears, get a 14 bolt out of a later model truck and replace the entire differential. there are a lot of them with 3.73, some of the later models even had 3.42 gears.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-10-2004, 08:03 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Fwiw,
My K20 axle bolts take a 3/4" socket. Stock (afaik) Eaton HO52 with 4.10s, coulda told you how many splines a couple weeks ago...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-10-2004, 09:07 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
For some reason I'm thinking 17 splines.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-10-2004, 10:32 PM   #7
Rod
17 it is.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
