Old 11-10-2004, 01:12 AM   #1
leastbay
Proper way to remove my shackles?
Ok i got some lowering shackles do i have to remove the u bolts holding the spring to axle first or can i just unbolt the shackles? not really sure how much tension will be on it thats why im asking
leastbay is offline   Reply With Quote
Old 11-10-2004, 08:40 AM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
You need to jack the truck up high enough to put jackstands under the frame, remove the wheels/tires, then lower the diff to remove all tension thats on the shackles. You do not have to remove any u-bolts although you will have to remove the lower shock bolts. Loosen the bolts and you will be able to tell there isnt any tension. The longer shackles will require you to cut/notch a support thats under the bed right above the shackle, so your gonna need a sawzall or something
Only thing to remember is DO NOT fully tighten the shackle bolts until the truck is back on the ground with wheels and tires and weight of the truck and then do not overtighten.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-10-2004, 11:03 AM   #3
Destructo
I think the proper torque on the shackles is something in the area of 35 lb ft? I'm a slacker and never use the torque wrench...
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
