11-10-2004, 01:47 AM | #1 |
My other Love
brake light and signal light problem
well the truck is hibernating for the winter now , but before I parked it, the brake lights worked fine, the signal lights worked fine, but when Id hit the brakes while the signal light was on, the signal light would quit, it does this when both the right and left signal light are used, so what gives?
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
11-10-2004, 06:29 AM | #2 |
its all about the +6 inches
Sounding like a turn signal switch.
11-10-2004, 08:15 AM | #3 |
67-72 Addict!
Andy is probably right. Look on ebay, there is a guy that sells new AC Delco turn signal switches for our trucks for like $14.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-10-2004, 08:30 AM | #4 |
Before you buy a new switch I would go thru and clean all the ground connections for your lights. It might help and it might not but at least its cheap.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
11-10-2004, 03:51 PM | #5 |
I doubt cleaning the grounds would do anything...the ground is good enough for the amperage of the brake lights, which is the exact same as the turn signal since it is the same filliment.
11-11-2004, 02:52 AM | #6 |
Active Member
I think it's working as it should. I think Andy's right that it's the same filliment and if it is it can't blink and stay on continous at the same time.
69 C10 LWB Project 47 Cushman Scooter Project It is better to have loved and lost than to live with a psycho all your life. |
11-11-2004, 03:02 AM | #7 |
Does the taillight quit, or does the dash indicator quit?
11-11-2004, 09:40 AM | #8 |
Always check the easiest things first, I say, cause I'm lazy. See if your front signals work, see if your bulbs are ok, see if your blinker is burnt out, and poke around with a test light before you pull your signal switch. As for blinking. The brake light / signal use the same filamint. The signal is just a blinking brake light
11-11-2004, 04:11 PM | #9 |
My other Love
all the bulbs are working just fine and all are really bright, its just when I have the signal lights on and I hit the brake the circuit that is flashing stop flashing and just dims
11-11-2004, 11:49 PM | #10 |
My other Love
found the problem today, I had one of those Hoppy inline tralier wire connectors in the back, and as soon as I unhooked it and plugged the taillights back in, everything started working fine, so there is obviously something wrong inside of the trailer connector
