View Poll Results: How many pumps
1 22 37.29%
1.5 1 1.69%
2 23 38.98%
2+ 13 22.03%
Voters: 59. You may not vote on this poll
Old 11-10-2004, 01:42 PM   #1
67chevemall
67chevemall's Avatar
Who's a one pumper??
How many times do you guys tap a tap the gas before you start it?
1,2,3,1.5,??
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-10-2004, 01:45 PM   #2
Putter
More Cowbell....
Putter's Avatar
Depends on the temp outside. If it is under the upper-50's, I have to pump, choke, cuss, beat, bang and then usually end up "SPRAYING" it.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 11-10-2004, 01:47 PM   #3
drink2mny
drink2mny's Avatar
The '72 and Olds in my sig I one pump.
The mud blazer on the other hand tires out your foot if its cold outside or has been sitting for awhile
Support The Board
drink2mny is offline   Reply With Quote
Old 11-10-2004, 03:37 PM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
I had to open the thread to make sure I knew what we were pumping. Two for me.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 11-10-2004, 04:06 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The GMC was a one pump before it surned into a milk shake machine...the caddy bieleve it or not is a 2 pump, even though it sits so much, it'll still fire on 2 pumps.
I tried pumpin the Town Car the other day....it wouldn't start for 2 hrs after that.
Old 11-10-2004, 04:20 PM   #6
724wdcopper
graphic designer
724wdcopper's Avatar
2 for me
i do the "key on, let electric fuel pump do it's thing for 1-2 seocnds, then crank while giving 2 pumps" dance every morning! if i dont get it in that first shot, better pull out the battery jump pack...piece of $#!& Delco battery! once it's warm, no pumps! twist the key and she goes!
724wdcopper is offline   Reply With Quote
Old 11-10-2004, 05:26 PM   #7
dtlilly
dtlilly's Avatar
I loose track between all the pumping, then getting out and pouring gas down it's throat, then cranking and pumping some more, then getting jumper cables hooked up, then more gas, then more pumping and cranking. Once it's primed and running, it doesn't take any pumps, just turn the key.
yes, I know the carb needs a rebuild, but it sure is a good theft deterent! :p
dtlilly is offline   Reply With Quote
Old 11-10-2004, 05:30 PM   #8
GMC71k20
depends on weather. i looked at a 71 bb cheyenne that started faster than any FI car ive started.
GMC71k20 is offline   Reply With Quote
Old 11-10-2004, 05:43 PM   #9
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I always pump mine about 5 times then crank it up and keep my foot in it to warm it up. I have a manual choke carb but I don't have the choke hooked up. When it starts to get colder I'll probably have to use it.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 11-10-2004, 06:47 PM   #10
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
2 Pumps here usually cause of it sitting overnight...but once it's ran for 15 minutes or more in the same day it starts without a pump there after.
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 11-10-2004, 06:51 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WHERE IS THE "0"
BLACKIE - 0
"GQ" IS 3-5
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-10-2004, 07:12 PM   #12
shortymac83
hmm...
shortymac83's Avatar
once. then crank for 5 seconds on the olds, and it fires right up
on teh truck, depends on it's mood. if it's good, pull the choke, don't hit the gas, hit the key and 2 cranks and it fires...otherwise, don't hit the choke at all, floor it and crank and it'll fire.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 11-10-2004, 07:18 PM   #13
lukecp
Formerly yellow72custom
lukecp's Avatar
My truck sits for 2-3 weeks at a time before driving it, and the electric choke is still in summer mode, so it takes about 20 for me to get it running. A few half way down pumps, then crank the engine, pump some more, stop cranking, maybe 5 to the floor, crank and feather it some more, then a few more to the floor and it starts and runs perfect.
But back when it was a DD in the cold morings it would take maybe 2 to the floor and it would fire right to life. Once i had been driving it, i just pushed the pedal down a slight bit and it fired right up.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-10-2004, 07:25 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
One, just enough to set the choke. If it's much below freezing, it'll run for a few seconds and die - then hit the starter once more (not the throttle) and it's off & runnin'.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-10-2004, 07:56 PM   #15
formerfordguy
72 GMC SWB
formerfordguy's Avatar
1 if that but the lowest its been here so far with this carb has been 32 or so most of the time i can just kick the key and it starts
formerfordguy is offline   Reply With Quote
Old 11-10-2004, 08:09 PM   #16
longnlow72
longnlow72's Avatar
ill put 2+ on the the pull cuz a little over 10 is what it takes lol the choke doesnt work
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 11-10-2004, 08:36 PM   #17
1972C10
1972C10's Avatar
Both My Trucks Start With One pump My 72 doesent even have a choke tower starts up great and runs fine yearround. The 85 has electric choke and a rebuilt Q-jet It idles high untill its warm and acts just like it should.
On anything with choke you really otta push the pedal at least once so the fast idle cam will engage .
1972C10 is offline   Reply With Quote
Old 11-10-2004, 09:38 PM   #18
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i really need to get my electric choke adjusted, it is about 10 usually every morning. but no pumps after it has fired
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-10-2004, 09:40 PM   #19
Peregrine
Peregrine's Avatar
I take credit for the 1.5 I can't explain it, that's just how I do it.
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 11-10-2004, 10:20 PM   #20
70 shorty
Where's my beer?
70 shorty's Avatar
Truck: haven't had it long enough to know, still a pain in the A@@ to get started.
81 Z28, 2 pumps. Sits for weeks at a time, and this works every time. After having driven it, just touch the key, it fires right up.
70 shorty is offline   Reply With Quote
Old 11-10-2004, 10:47 PM   #21
mr402
1 Pump. My 71 402 starts faster than just about anything else I have including my 00 Jimmy and 99 Regal. Back in the late 70s when I lived back east there were some cold days when the Chevy was the only vehicle that would start.
mr402 is offline   Reply With Quote
Old 11-10-2004, 11:13 PM   #22
3 on the tree
How many pumps?
My Chevy motored Cherokee 2 pumps, die , 2 more run. My 70 6cyl K5 5 pumps. My 79 Dodge 1 pump. My 77 440 Dodge 10. My wife's Citation-just look at the pedal and hit the key!
3 on the tree is offline   Reply With Quote
Old 11-10-2004, 11:14 PM   #23
dinnut
dinnut's Avatar
my 70 fired right up w/ no pumps with the stock quadrajet with a busted choke. now it has a holley w/ electric choke and she fires right up might need a pump or 2 but thats because its cold now.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-10-2004, 11:51 PM   #24
Longhorn Man
Woah...there's a citation that still runs?
I had one in high school....broke the sucker in 1/2...literally.
Old 11-11-2004, 12:52 AM   #25
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
Depends on my engine temp... the 454 doesn't like colder engine temps than 45 or so too well. If it's 45+, then I just turn the key and let it crank for several seconds until it starts to fire then I give it a little gas to get it going, then give a few small revs to make sure it stays running. If it's gonna be cool or cold, I usually have it plugged in (hose heater), and it starts almost right away. If the engine temp is in the 30's or below... it's a b!tch to start. Pumping it doesn't help, just floods it... I need to get my choke working correctly before it gets TOO cold...
Of course I just ordered a new harmonic balancer and as soon as I install that I need to get it timed correctly. Then fix the choke and tune the carb. Then hopefully I'll be ready to burn off those old tires of mine....
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
