Old 11-10-2004, 03:57 PM   #1
70short
Th400
I want to install an Auto TH400 in place of my old truck 4-speed. I have A 69 donner truck for the swap. Do I need the crossmember out of the donner truck or will mine work? I looked at my crossmember and it looks like it will be A pain to drill the rivets (upper 4). There is not alot of room to drop bolts into the upper holes for the swap. Do I need to lift the CAB? I cant wait to finally get An "AUTO" in place of the "OLD TRUCK 4-SPEED" Any help would be greatly appreciated! THANK YOU!!!!!!!!!!!
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 11-10-2004, 08:24 PM   #2
john@thepier
john@thepier's Avatar
depending on the cross member you have it will more than likely need to be swapped out.my 3 on the tree cross member had to be removed and replaced with a auto cross member.grinding and nocking out the rivets required me to have to un bolt the front of the cab and jack it up a little in order to fit my grinder in there.and that was after the engine and front clip was removed.soon I will be slipping in my new 400-400 combo GOOD-LUCK
john@thepier is offline   Reply With Quote
Old 11-10-2004, 08:29 PM   #3
JimKshortstep4x4
Smile
You will need the auto cross member. If your cab mounts are bad you may need to lift the cab slightly to install the bolts, but I have not had a problem installing the upper bolts.
Old 11-10-2004, 11:02 PM   #4
Hooter
My other Love
Hooter's Avatar
you shouldnt need to lift the cab to accomodate the turbo 400, the 4 speed cab has a higher hump then an automatic cab anyways. Swap the crossmembers, by a new tranny mount for the crossmember because chances are the old one is toast anyways.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-11-2004, 08:37 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Quick Tx Firefighter Easy Method (TM) of removing the manual crossmember with the cab still on. Using Sawz-all, cut the center of the crossmember out to where there are just 4 wings left riveted to the frame. Now, slice the rivet heads off with the sawz-all. You can sneak the saw blade on top of the frame, between the frame and cab and nip the heads right off. Now hit each wing with a sledge hammer. It will pop right off and the rivet stubs will come out with it. Takes about 15 minutes a 2 blades to remove one this way.
I cringe every time I hear someone taking half a day to get one of those things out.
Old 11-11-2004, 01:59 PM   #6
70short
Talking Scrap It
TX I like your method! The crossmmber is not going back on anything. OK so I guess I can't use my 4-speed crossmember UMMM SAWS-ALL CUTTING TORCH !!!!!!!!!!!!!!! It seems to me that the holes are predrilled for the AUTO crossmember back (AFT) from the 4-speed holes??? generic. Thanks everyone anymore input would be greatly appreciated!!!!
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 11-11-2004, 02:11 PM   #7
Tx Firefighter
Yes, the holes will be there to meet you when you get ready. Get the proper 67-72 automatic crossmember and (8) 3/8 bolts and nuts.
Old 11-11-2004, 02:44 PM   #8
mrein3
mrein3's Avatar
When I swapped my manual 4x4 to a th350 4x4 I spent 5 minutes with the blue wrench blowing out the rivets that held the center part on.
I cringe every time I hear someone taking 15 minutes to get one of those things out.
Jusk kidding of course about the 15 minute crack. However it did take about 5 minutes to blow them out.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-11-2004, 04:25 PM   #9
70short
Wow
I still have to get the AUTO crossmember out in good shape. No air compressor where that truck is located. Did I mention that I bought the whole truck for $300. The only thing I do not get is the 396 BIG BLOCK. Fire damage in the eng bay. Blistered fenders and hood " so what". Straight 3/4 ton AIR cab. 4 core RAD. I am stripping this truck. OH and the interior is clean, the bench seat is nicer than the one in my truck now.
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 11-11-2004, 06:00 PM   #10
Tx Firefighter
Getting the crossmember out of an auto truck is easy, it just unbolts, no rivets.
