Old 11-11-2004, 01:35 AM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Exclamation How do I remove the trailing arm bushings
How do I remove the bushings on the rear trailing arms? Do they have to be pressed out?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 11-11-2004, 02:24 AM   #2
cduster
I used a torch and melted the rubber out, and then pressed the metal sleeve out.
cduster is offline   Reply With Quote
Old 11-11-2004, 05:03 AM   #3
68LSS1
68LSS1's Avatar
Same here. Let the fire burn long enough and the bushing will fall out.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 11-11-2004, 06:36 AM   #4
beautimus
beautimus's Avatar
i put a brick under my trailing arm right beside the bushing and used a bfh.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 11-11-2004, 08:13 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I use a big air hammer on them.
Old 11-11-2004, 08:48 AM   #6
phase_one
Torch em
11 Surbaban
70 C 10
still in progress
phase_one is offline   Reply With Quote
Old 11-11-2004, 08:56 AM   #7
Tx Firefighter
Originally Posted by phase_one
Torch em
You'll still need stong persuasion to get the remaining outer shell out, whether from a hammer, air hammer, or press (if you're the sophisticated type :p )
Old 11-11-2004, 09:02 AM   #8
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I used a C-type ball joint press to get them out and the new ones back in.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
