11-11-2004, 03:15 AM | #1 |
After you have cut the rust out.
After the rusty area has been cut away and a new piece put in, do you sand , prime and paint that one area?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-11-2004, 03:41 AM | #2 |
Still drivin' a Rat Rod
grind the welds,body filler if neccesary,sand smooth,prime,and paint.Don't leave any metal exposed You'll have the same proble begin again.
It's OK in primer for a while if you're painting the whole truck
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-11-2004, 08:06 AM | #3 |
1969 Custom 30 wrecker
It's a good idea to use weld thru primer on the bare metal before you weld it in. Once all the welding and grinding is done, I spray an etch primer, then treat the rest the same as regular body work.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
11-11-2004, 02:01 PM | #4 |
Thanks for the tips. My plan so far is this.
1. Identify area that needs cutting. 2 cut out what needs to be cut. 3. rust more that area and let it sit until it cures. 4. spray weld through primer on the area and let it cure. 5. weld in the pieces. 5. grind the welds down. 6. primer and paint the area 7. seal the area. Did I miss anything? Thanks
11-11-2004, 02:49 PM | #5 |
Weld through primer? I did not know there was such thing...? It doesn't contaminate the weld?
What brands? Where to find? etc.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
11-11-2004, 02:59 PM | #6 |
I dont remember the brand name. Its at the house. I can look and post back later tonight.
11-11-2004, 04:15 PM | #7 |
Weekend Warrior
weld thru
3M and SEM make it in spray bombs...but it is kinda pricy $20 for the 3M
Most paint makers have it..just go to a parts supplier that carries paint of you local paint provider
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
11-11-2004, 05:01 PM | #8 |
The original purpose of weld through primer was intended for when two panels are overlapped and welded together and plug welded such as replacing a quarter panel on a vehicle. You are not acutually supposed to weld over weld through primer. It contaminates your weld. You will have a lot of pop and splatter. It should only be applied in between your weld areas. It wouldn't hurt however, if you could butt weld in a patch panel and then spray the welded area from the back side after cleaning the area of course. Then undercoating as needed. This is straight from a 3M rep himself in a training course for my bodymen. I manage a Chevrolet Dealership's collision center.
11-11-2004, 10:34 PM | #9 |
I have various opinions, but a lot of people prefer an epoxy primer before any fillers as then there is no chance of moisture getting behind the filler.
For what it's worth, Dave |
11-11-2004, 10:49 PM | #10 |
Is there a specific epoxy primer that I can use? I dont have a spray gun. Is there a rattle can version that I can use that will hold me over until I get the cab media blasted and painted?
11-11-2004, 11:14 PM | #11 |
Depending on where it is at I would just get a 30.00 quart of epoxy based primer and mix some and brush it on. You will use a sandable filler primer over the top anyway. And if it is under carpet or floormats it won't matter. That is what I am about to do with my 69.........
Dave |
11-11-2004, 11:28 PM | #12 |
Ok im a little lost. So do you put the epoxy primer on first then put the sandable primer on and then paint? Sorry I dont do body work.
THanks
11-12-2004, 12:19 PM | #13 |
Epoxy primer or etch primer first. ,, then the sandable filler stuff ( soft and easy to work) to establish a smooth finish for the top coat. I have another post going for a long time question of when to do the Bondo filler for haeavy scratches and dents that can't be worked out with conventional body hammers.
Dave |
