What do we get for $10?
Hydraboost brakes
Just wondered if someone could tell me me advantages of hydraboost (sp?) brakes. I've got the whole system on a parts truck and wondered if it would be worth the time to convert my '77.
Thanks, Joe
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ![]() |
Thanks for the response, ZOOMY. Would you know the reason they're always on 1 ton trucks? Higher pressure or something? Would a transplanted 1 ton front axle with the 1 ton's brakes need the hydraboost?
Joe
I believe there usually on 1 tons cause hydro boost brakes stop better. 1 tons are usually towing & are very heavy. Hydro's will help said vehicle stop faster. Im building a 71 3/4 ton & want to do a hydro brake system. I havent started to search for parts yet. Let me know if you want to sell your hydro stuff if you wont be needing it. Its a bit of a pain to set up the hydro system, & i wouldnt be considering it but i tow to much. My 2004 3/4 ton suburban has it & it stops so much better while towing. Let me know. Thanks Todd
All my trucks are gone now. ![]() ![]() |
hydroboost
Hi, I have a complete hydroboost setup on my plow/parts truck. I was planning on converting my stepside when I add the other hardware. I am curious too as to why the hydroboost is better, I just figured it would make sense to transplant everything so it would all match. Thanks!
Crosby 1978 Chevrolet K10 stepside NH |
#5 | |
Joe
Ok Joe. Thanks. wheres Beardstown located?
You don't know? (LOL
![]() Joe
Hydraboost stops better than any vaccum booster I've seen. My 80 C-30 weighs 7000lbs.empty but stops like a pickup.Before I installed a bed it would lock the rear tires just tapping the brakes!
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 |
Looks like a nice dually.
Pics for Todd
Here's some pics of the hydroboost setup.
Now it's Miller time! ![]()
I was wondering, since I have the brake set up pictured on a parts truck to, is there a special power steering pump that should go with it, or will the standard single outlet pump work. I was thinking on swapping this on my 1/2 4x4 just for better braking.
The pump on my 80 c30 looks a little bigger than on my 79 k10 maybe just extra fluid ? Both are 350ci
#14 | |
69k5 |
#15 |
![]() Join Date: Dec 2006
Re: Hydraboost brakes
There's one out at the self serve yard,1/2 price on everything this weekend.
Here's a pic. ![]()
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#16 |
If you have hydroboost and havent changed your power steering fluid in a while, DO IT, I used some Valvoline Synthetic PS fluid in mine, with a 6' length of 3/8" hose over the return line into a washer fluid container, ran about 2 quarts thru and it stops like a new truck, altho I am talking about my '01 with 145xxx miles... It really makes a difference tho.. Oh, and if you have hydroboost, you could run a REALLY BIG CAM
![]() Brandon |
