11-11-2004, 04:05 PM | #1 |
tranny for 327
Here's a question.....I am putting a 327 into the old 49 chevy. Which tranny would be good to use?? I have found a 350 turbo with overdrive which is in a truck attached to a 305 motor. I was told by a friend that the auto tranny that came in the 88 chev s-10 with a 2.8 liter v-6 which I have would work ?? Dont know about that one though. Any help would be nice thanks
11-11-2004, 04:40 PM | #2 |
Led Sled! Discs R 4 ME!
If you have a overdrive trans then its not a TH350.
What would bolt up to the 327 is a 700R4 from A SBC or a 4.3L. A 2.8L has a different bolt battern Its a 60 degree V6 where as 4.3L is a 90 degree V6 Which is the same as the V8. If its an overdrive trans connected to the 2.8L odds are its a 200R4. This is still a good trans although bolting it to a 350 would requite other adaptors that may make it cost prohibitive. Hope this helps. |
11-12-2004, 10:45 PM | #3 |
Still drivin' a Rat Rod
The 700r4 would be a good swap.The overdrive will greatly improve MPG.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-13-2004, 09:46 AM | #4 | |
11-16-2004, 09:03 PM | #5 |
One of my grandpa's has a s-10 with a 2.8. And Denny is right, the bolt pattern is different. Your friend was probally thinking about the auto's that come with the 4.3, instead of the 2.8.
54 Chevy Bel Air 4dr powerglide 54 Chevy SWB 58 Chevy Big Window SWB Fleetside project 58 Chevy LWB 235/4spd 76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine 79 Chevy 4x4 SWB 350/4spd 3/4 ton 81 Mazda RX7 84 F@!d Mustang 96 F@!d Ranger 2.3L/5spd |
11-24-2004, 12:19 AM | #6 |
thanks...I'll go with the 700r4...not a bad deal trading the 200,000 mile plus 2.8 and it's trans for the 700r4 with 80,000 miles on it
11-24-2004, 12:38 AM | #7 |
No I'd do it
11-24-2004, 08:41 AM | #8 |
With a 700r4, have at least 3:73 gears. Anything higher may rob you of mpg.
