Life, Be In It.....
![]() Join Date: Oct 2003
Need pics of air bags on rear trailing arms. I want to know if I need to do anything to my frame before I have it powder coated.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
turnin wrenches
i don't have a camera that works at the moment but, my bags bolt in in the same place as the stock coil spring. however i would suggest that you c-notch your frame and do all modifications before powder coating to ensure good fit and finish. that way when you get your frame back, all you have to do is put it back together
good luck BBB
"three can keep a secret if two are dead" -unknown hell's angel- D.M.C. -FF- 68 SWB full frame off (project ol skool) 2000 s-10 formally bagged but now my daily driver... |
Too Many Clubs Club
Rear bags on Blazer frame. Mounting on a truck frame is identical.
How I installed my air bags... |
Life, Be In It.....
MR Shelly
Do you have any pics of how the bags are attached and plumbed for air delivery? I noticed that yours is not c-notched any reason why? Thanks
Got Light Emitting Diode?
looks c notched to me
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Too Many Clubs Club
The pics are not of my truck, just one I saw this summer at Texas Heatwave. It is C-notched (as 68w/sbc406 noted). My truck is also notched, although a little differently to accomodate the Early Classic extended track bar.
As far as attaching the bags to the frame, the bottom of the bag bolts to the trailing arm with a single bolt and washer (3/8" I believe). The top requires drilling three holes in the frame, or using a bracket like Air Ride Tech makes. Check this thread for more info and pix concerning rear bag mounting. Here's a pic of how my frame is notched on the passenger side to provide clearance for the extended track bar.
Life, Be In It.....
Mr Shelly
Would this C-notch cause problems with the super track bar from Early Classic?
#8 | |
Seņor Member
#9 | |
Life, Be In It.....
#10 | |
Seņor Member
Seņor Member
Here's a shot of mine. I extended the opening in the c-notch so the bar could clear. Others have modified the bar end bracket, but my method keeps the bar more horizontal, which is the ideal position for a Panhard bar. Either method works though.
Life, Be In It.....
Perfect. Exactly the information I need. Thanks for the detailed explaination and pictures. It really clears things up for me. Now I just have to decide C-notch or no C-notch.
