Old 11-12-2004, 03:54 AM   #1
lost wages
lost wages's Avatar
sway bar help
ok, this should be an easy thing to put together but im lost. I have a 1 1/16 sway bar off a 69 2wd half ton. I ordered the lowered brackets from early classic and poly bushings along with the other parts i needed. It was all fine but the bar sticks out of the bushing 3-4 inches where it is mounted on the control arm and rubs my air bag. i have turned the bar and brackets different ways with no solution. WTF am i missing? i knocked the rivets out of the crossmember and have studied the FAQ section with the write up on this swap.
lost wages is offline   Reply With Quote
Old 11-12-2004, 04:52 AM   #2
OhioDan
OhioDan's Avatar
Sounds like your brackets on the frame are mounted to far to the rear? Just did this mod, and had no problems.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-12-2004, 08:15 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you trimmed the ends of the bar, would it work then?
I have no idea of what it would take to trim a swaybar though. I think they are made out of the same steel as the door hinges of Hell are.
Old 11-12-2004, 09:07 AM   #4
Huck
Huck's Avatar
Correct original sway bar should extend no more then an inch beyond the lower A frame mounting bkt. Make sure you have the frame brackets in the correct place and are mounted correctly---. They usually are a pretty easy install--bolt up. If still an issue, post a picture so we can see what you are dealing with and can advise---be sure to show which mounting holes you are using on the frame. Huck
Huck is offline   Reply With Quote
Old 11-12-2004, 12:13 PM   #5
lost wages
lost wages's Avatar
the truck has a 77 front crossmember under it and a 68 frame, would the newer front end be more forward maybe?
Old 11-12-2004, 02:11 PM   #6
Ole Blue
My truck has the 1 1/16 bar on it if you want to take a look at the factory install. I won't be home this weekend but the truck will if that helps. If you decide that you need to cut the bar I've got the stuff to make it a snap. I haven't forgotten about the front end alignment and scales for your truck, some stuff came up and got real busy. BTW Do you have the alignment specs that we would need? Like I said the truck will be out in the driveway if you want to scope it out. Take care, Bart
72 Cheyenne Super waiting on 4/6 drop,BB and 700r4
Ole Blue is offline   Reply With Quote
Old 11-15-2004, 01:36 AM   #7
lost wages
lost wages's Avatar
ttt
Old 11-15-2004, 01:56 AM   #8
Josh
He's got mean nasty FANGS!
Josh's Avatar
One last pic for lost.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 11-15-2004, 01:58 AM   #9
lost wages
lost wages's Avatar
thanks jzero
Old 11-15-2004, 08:04 AM   #10
Tx Firefighter
Trim an inch off the ends and you should be good to go.
I have no idea why your bar hangs out of the back of the brackets like that. It's obviously installed correctly.
Old 11-15-2004, 09:50 AM   #11
Huck
Huck's Avatar
Wo baby----not liking what I see here. Will take a picture of a stock setup and get back with you--- don't cut that bar just yet~~~~!
Old 11-15-2004, 10:27 AM   #12
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
It looks to me that as the frame is lowered (moving the front of the bar down) and the lower control arm becomes closer to the frame (control arm moves "up", raising the rear of the bar), the rear of the sway bar would rotate up, closing the distance between the mounting point on the arm and the end of the bar. In other words, as the bar rotates up, the end of it naturally will swing farther back until it reached a level point, then move away from it again.
Clear as mud? I can picture the motion in my simple little mind, but not sure I am explaining it well enough. But, imagine having the truck up on a lift, with no air bag installed, and the lower control arm in this position:
Now, start pulling down on the control arm and the sway bar should start to pull through the bushing closer to a normal position as it rotates down. I'm thinking that shortning the sway bar a little should do the trick, so long as there is not too much trimed off so that it could slip out if the front suspension reached full extension.
Just my $.02
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-15-2004, 01:01 PM   #13
lost wages
lost wages's Avatar
i had the truck on jack stands(not in these pics) and the a arms just hanging and it still was long.
Old 11-15-2004, 02:17 PM   #14
rigo
Flake Daddy
rigo's Avatar
the front of mine is bagged...and as I recall...mine was rubbing on the bag as well....I simply trimmed off the back edges a little at a time till I found what I needed...
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 11-15-2004, 02:25 PM   #15
71Chev
71Chev's Avatar
Looks like the center frame brackets are mounted in the wrong holes. The rear hole in the frame brackets need to be in the hole that front lower crossmember rivet was in.
edit: I can't tell for sure if the brackets are mounted in the correct location, all that silver has my eyes playing tricks. But it's sure nice to look at.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 11-15-2004, 02:26 PM   #16
glock35ipsc
Well, what I would do then is get the front end up on jack stands (on the frame) so that the suspension is at full extension. First, be sure all the mounting hardware for the sway bar is fully tightened. Then mark the end of the bar so there is at least 1/2" to 1" still hanging out the end, and cut them there. At least that way you know they will not come out of the bushing when you Dukes of Hazzard the next bridge!
Bob
Old 11-15-2004, 02:33 PM   #17
glock35ipsc
I'm pretty sure they are. I pulled out some pics of mine and they are in the same spot. I'm kinda puzzled as to why is would be too long, but I think he would be OK to trim them after some careful measuring.
Bob
Old 11-15-2004, 03:01 PM   #18
neonlarry
neonlarry's Avatar
It may be my eyesight or just the prespective ( my bar is 1ΒΌ") but that sway bar looks like the arms are longer than my bars. Mine measure 14 1/8" from the front of the bar to the end of the arm, check the measurement on yours.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-15-2004, 08:18 PM   #19
Huck
Huck's Avatar
My frame mounting brackets drop about 2 3/4" in the rear which look like it is more then yours. They mount---rear hole in the front crossmember hole on frame and the front bracket hole aligns in the first circular hole behind the ovel one. My sway bar extends maybe 3/4" beyond the lower A frame mounting bushing.
