11-12-2004, 06:17 PM | #1 |
C/10 CLUB MEMBER
Fuel Line Question???
Is the rubber line from the main tank to the metal lines 3/8" line? Im still trying to figure out what is wrong with my truck. And I know that one of those lines was cracking and leaked at one point. The reason I ask is because I haven't gotten back under it since I broke my wrist.. Now that the cast is off im ready to get back to work. Just wanted to know if that is the correct size so I can go buy some before I crawl under that baby.
thanks, Ron
-Ron- |
11-12-2004, 06:45 PM | #2 |
Its 3/8 or 5/16
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
11-12-2004, 09:38 PM | #3 |
Watch out for your cornhole !
6 cylinder or 307 got the 5/16.
350 or big block got the 3/8 line.
11-12-2004, 09:41 PM | #4 |
My 81 has 3/8 up to the fuel pump, then changes to 5/16 to the carb.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
11-12-2004, 09:48 PM | #5 | |
1) he posted in the 67-72 section 2) his signature says 71 model truck
11-13-2004, 02:01 AM | #6 |
C/10 CLUB MEMBER
thanks guys hope that is the problem
-Ron- |
11-13-2004, 06:30 AM | #7 |
Cantankerous Geezer
Let me add a bit of advice. When connecting rubber hose to tubing without a bead on the tubing, it is difficult to get a good seal, especially with gasoline. You probably won't see the leak, it will be that slight. But if your truck sets for a few days, you will notice that you have to crank the engine for a little bit to get fuel to the carburetor.
To help with this, use Permatex Hylomar . This is a non-hardening sealant developed by Rolls Royce for use in carburetors and is the only gasoline resistant sealer that I am aware of. Wipe a little on the tube, install the hose and clamp. It works great.
Fred There is no such thing as too much cam...just not enough engine. |
