Old 11-12-2004, 10:17 PM   #1
DCRANER
Carpet kit suggestions
Going to re-do my 86 GMC carpet, puting in APC bucket seats also, but what is the best brand quality carpet set?
I am looking at Trim Parts because they have the floor carpet and matching door bottom carpet, as well as matching mats.
I know a while ago Swervin made a suggestion, but do not recall which brand he suggested.
Thanks.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
Old 11-12-2004, 10:38 PM   #2
Destructo
I'm going to be looking too, I just ripped out all my vinyl flooring and old moldy soaking wet insulation, but won't be putting any carpet in until I fix the leaks and re-paint the floor. I am hoping to find some full carpet that runs all the way back, and I need some sound insulation suggestions also, I hear dynamat it good, I plan on running it all the way up the back of the cab.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 11-12-2004, 11:08 PM   #3
DCRANER
I did my carpet, ACC Carpet about 5 years ago and when I ordered the kit I was able to request an extra matching section to cover the rear of the cab behind the seat, and tucked it under the rear window rubber strip. This worked very well. I also first did the Dynomat on the floor and the rear of the cab.
I can tell you one of the common places for a leak is above the firewall, just under the wiper area. If you remove the cowl and have someone spray a hose on that area you may find a leak and / or clogged drains. I sealed my area with 50 year outdoor silicone weather caulk, and also shine a drop light at night in that area and look for light coming in the interior area. Sounds like a lot, but easy to do. My 86 GMC is garaged, but can sit in a thunderstorm and is bone dry inside, not a drop.
Good luck.
Old 11-13-2004, 01:50 AM   #4
Destructo
hmm, I had the cowl off once already trying to track down a leak and cleaned it out and everything, didn't think about checking the seal on it though, turned out to be the passenger side vent which is back to leaking again (easy fix).
I thought it could only be the windshield, so i'll check for leaks there in where they meet under the cowl.
Thanks for the heads up!
Old 11-13-2004, 11:26 AM   #5
Jonboy
Slots go on anything!
I used the Trim Parts Carpet in my truck. It seemed to fit pretty well. My truck was a non A/C truck, and I used the extra carpet to cover the kick panels and door lowers as well.
I think Captkaos is an ACC dealer, if you want to go that way again.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-13-2004, 11:32 AM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
Classic Industries sells ACC, they want a hundred bucks for the floor carpet, but they don't sell the kick panel pieces and lower door pieces. LMC sells carpet from somebody, and they have matching lower door panel and kick panel pieces for a decent price. I've been following this thread cause eventually im gonna do carpet.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 11-14-2004, 12:46 AM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You are correct. I can also get extra carpet by the yard most likely if you need it. I got it on mine the last set I ordered.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-14-2004, 12:36 PM   #8
hotrodhomi
hotrodhomi's Avatar
I bought mine from here. http://www.1aauto.com/1A/CDManuals/C...PickupCKSeries
I was happy with the quality.
HRH
hotrodhomi is offline   Reply With Quote
Old 11-14-2004, 09:21 PM   #9
Destructo
Who makes molded carpet with all the holes cut in it? I'd rather spend a little extra and get molded carpet that I can just drop in rather than have to cut the holes in and all that.
Old 11-14-2004, 11:18 PM   #10
hotrodhomi
hotrodhomi's Avatar
The carpet I used from 1AAuto was molded but I needed to cut wholes out for the headlight dimmer and the front two seat brackets. If you cut from the back, it will turn out perfect. Mine did.
