11-13-2004, 10:44 AM | #1 |
nother split rim question
i just got a 68 cab and chassis C 30. it has what i at first thot were split rims in the rear,but after doing a search and looking at some pics,i dont think that it does.
they have what looks like the flat part of a wheel stud visible around the rim,where the center meets it. i dont know if they are actually some sort of stud,a big spot weld or what. but at any rate,they look like normal rims,i cant see any wierd lockrings or anything.one of the tires is flat and seperated from the bead,and it looks like any other wheel. also from what i gather,most,or all,split rims used tubed tires. these are a wierd size,but are tubeless. they are an 8-75, 6 ply rated sidewall, "courser traction" tire. i plan to use this truck to pull a large goosneck trailer,after giving it some TLC,of course. i dont mind running the 17.5 size till its time for tires,as long as they are not unsafe or dangerous. can anyone confirm my thots that this is a normal wheel? if not anyone got any pics of different types of dually splits to compare em to? the only pics ive been able to find on here so far have all been of single wheels. if its a normal wheel,anyone got anything to say,good or bad,bout the 17.5 size? thanx a bunch |
11-13-2004, 01:21 PM | #2 |
Half a bubble off!
Just stop at any tire shop, they can tell you real quick by looking. If they are split rims, get rid of them pronto (that's my opinion of them).
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
11-13-2004, 02:10 PM | #3 |
IF THEY ARE TUBELESS, THEY ARE NOT SPLITS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
11-13-2004, 02:38 PM | #4 |
Got Light Emitting Diode?
i worked for a company that had a bucket truck that had split rims on it and we took it down to have new tires put on it and they refered to them as 'widow makers'and would not tuch them other than take them off. we had to buy new wheels.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
11-13-2004, 03:28 PM | #5 |
Lovin' Arizona Since 1961
I drove an 18 wheel end-dump truck as a kid and repaired my own flats, of which I had a lot from driving in dumps. I could do 10 of them in a day. These were big mother truck split rims, not them little tinky 16" ones like on pickups. I'd do all the repairs at one time, then air 'em up. The old drivers would leave the scene immediately. If you've ever seen one of those rings come off under high pressure you would leave the scene too. I would wrap a big piece of chain around it several times, then put a huge rug on the thing, clip the air chuck on, then get the hell outa there. They'd air up to 100 lbs. which is a freakin' bomb. Never popped one, but was across the street from a shop when one did explode. Flourescent fixture chunks flying and guys running out of there at high speed. Nobody hurt. CHEAP lesson.
I'm not sure why they ever made them for a 3/4 ton pickup with a GVW as low as they are (for a truck). Very few tire shops will touch them and your Discount Tire - Big O Sam's Club etc. weenies wouldn't have anybody who knew how to work on them even if their insurance would let them. Good advise above: Steer clear of them. You don't need them on a pickup. You won't be able to give them away when you do take them off your truck. There have been a lot of threads on the limitation of wheels available to 8-hole users. Regards, H.
"Religion is like a toothbrush: Everybody should have one, but I don't want yours" - Will Rogers |
11-14-2004, 09:03 AM | #6 |
thanx for the replys fellas. believe me,if they were splits id be puttin all 4 of em right in the trash can. i think they not,as they are a tubless traction tire,and the one that is flat does not have a tube in it. the truck runs and drives,but is not yet roadworthy. as soon as i get everything working i will take it by a tire shop and have em looked at,just to be sure. i have read some threads about needing new wheel studs in order to use newer wheels.
thanx again,im sure ill have some more qustions as i start gettin it fixed up
scotty 68 C 30 87 Subruban |
11-14-2004, 10:39 AM | #7 |
Active Member
Just because they are tubeless tires doesn't mean the rims aren't split. Some split rims had a solid outer ring with a snap type ring that fit between the rim and outer ring, so call safety split rim as the outer ring would force snap ring to lock into the rim. I would take it to a tire shop to make sure.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
11-14-2004, 10:58 AM | #8 |
If they are split rims you will see a split (1/8" gap or so) in the rims somewhere. Also a separate steel ring around the Bead lip with a gap in it also. These splits should be opposite each other.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
11-14-2004, 12:41 PM | #9 | |
11-14-2004, 12:52 PM | #10 | |
Watch out for your cornhole !
Absolutely true. My 72 has slpit rims, but there is a solid ring, with no gap in it. This is the best picture I have of them right now....
11-14-2004, 02:54 PM | #11 |
Registered Cruiser
I had a 67 with factory 17.5's... Not split rims... Check Sears for your tires. They used to have a small selection of them in that size. They aren't very common... If memory serves me correctly. No tube type tires are manufactured in .5" sizes. I had 8.00x17.5's with a highway tread. They lasted forever, but the grip on wet roads was awful.
I intend to live forever. So far, so good. |
11-14-2004, 05:49 PM | #12 |
here are some pics of spilt rims.the one ton one is a 18" rim.the outer ring is removable.the 3/4 ton wheel is the same if you look close you can see the split in the ring.the16" one is what i put on my 1 ton they are of an 84 truck.please do not ask if i would sell the split rims,unless u need a good fire pit!!! .these rims should be removed from service just my .02 cents
11-15-2004, 01:46 PM | #13 |
fwiw....i have splits on my 67 3/4 ton. i was going to get rid of them (i had heard horror stories) but there is a great tire place here in KC that works on semi's etc. they have no problem working on them. i asked if i should swap them and they asked "why? they are no big deal if you know what you are doing" The farmer relative i bought the truck from said the same thing...."i've changed those tires dozens of times....they are fine".
my understanding is they are dangerous when being inflated. if my tire goes low or flat, i take it in. somewhat inconvenient but it's not a daily driver. |
11-15-2004, 02:25 PM | #14 | |
Cantankerous Geezer
I have a local tire company that works on the rims for my 52. I still have the lock-ring style, a two peice rim that is fairly safe. So far, I have been unsuccessful in locating rims for the front axle on the 52, they have and odd setback with minimal clearanc for the tie rod end.
Fred There is no such thing as too much cam...just not enough engine. |
11-15-2004, 06:35 PM | #15 |
72 C30 Trailer Queen
I was recently told by an old heavy truck mechanic that all the sizes ending in .5 are single piece (or drop-center) rims.
16.5,17.5, 19.5 and 22.5 come to mind. Can anybody verify this? Cant say that I have ever seen 16.5 splits. |
11-15-2004, 07:06 PM | #16 |
its all about the +6 inches
I have seen a split ring fly off a day or two after it was assembled and aired up...it was bolted onto the truck and just blew off...luckily at night.
This is one of those things that, while thay can be safe, I wouldn't want to trust anyone but myself...and this is one area I DON'T trust my self in. |
11-16-2004, 10:49 AM | #17 |
thanx again for all the info. you guys seem like good peoples here on this board,guess im used to things over on pirate4x4 where you need flame protecton if youre asking a question thats allready been asked,ever in history. ill hafta make this place one of my daily stops
dean those pics are especially helpfull. my wheels dont look like either the top or the bottom pic. thanx again for all the info and great attitudes
11-16-2004, 12:49 PM | #18 |
My grandfather had a 67 half ton with split rims. They are still on the rear end of the truck that was made into a trailer in the early 70's. I think they are 16.5's Never looked very close at them but now that this comes up I am absolutely sure they were 6 bolt split rims. they may not be chevy though. they could easily be international or something. I think they are original though cause one of them still has the original hubcap on it. I stole the posi out of it and just put back in junk carrier with nothing but axle gears, c-clips, and the retainer.
Nathan Wheeldon
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran Nathan & Tiffany |
11-16-2004, 07:18 PM | #19 |
I've got a set of 'em from my truck, and another that I use for a spare. They're really skinny 7.5/16/LT's. I've changed a couple of these before but I had an old timer there watching me to make sure I put the rim together right and I've been lucky I guess. These rims aren't really dangerous except when you air 'em up, put 'em in a cage or wrap a huge chain around it a couple times and get the he!! away while it starts to air up. I tore down my spare and cleaned it up and painted it, and I worked on a couple from the old 67-72 style c50/c60 grain box trucks, they have 10 lugs. Those SOB's are fun to work on! Here's an old pic of my spare tire from like 4 months ago:
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
11-16-2004, 09:00 PM | #20 |
Still drivin' a Rat Rod
We used to slide the split rims under the car lift at the filling station to air them up.I have seen one come off.Sounds like a bomb,and lifted the lift with a ford truck on it a foot in the air.
We finally have cycled all the split rims out of the farm.The last two left in the spring.I refused to fix them.So once they go flat,swap the tire on the one piece or replace the tire and toss the split wheel in hte scrap pile.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
