Old 11-13-2004, 11:19 AM   #1
jberkeley
86 chevy k-10
Question tilt column
i have a tilt column with a lot slop..does anybody know if a rebuild kit is available? or maybe a new shaft, if anyone knows please let me know..thanks j berkeley
jberkeley is offline   Reply With Quote
Old 11-14-2004, 12:43 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Depending on what is causing your slop, this might fix it. He refers to the loose screws, a common problem, as "loose tilt mechanism."
http://home.t-online.de/home/O_Scholz/steering.html
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-14-2004, 09:35 AM   #3
jberkeley
86 chevy k-10
thanks for the reply, the problem seems to be in the wheel side to side. when i rebuilt my jeep, they made a kit for the shaft. and that made it a little firmer.. so i guess what i'm looking for is a rebuild kit for the shaft.. thanks again...
Old 11-15-2004, 08:37 AM   #4
Mike76251
I had the slop too and those four little torx screws were what was causing it.
Fixed it last week and it was pretty easy.
Just make sure you get the lock plate remover and the wheel puller before you start.
Mike76251 is offline   Reply With Quote
Old 11-15-2004, 12:37 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Be sure to dope those four screws with blue Lok-Tite, so that once you tighten them, they stay tight.
piecesparts is offline   Reply With Quote
Old 11-15-2004, 01:25 PM   #6
mckpaul
mckpaul's Avatar
Yep, did that fix myself. If you look around on the net, there are a couple of places you can find info. When I did it, I found a site that had step by step instructions with pics. I just printed it and referred to it as I went. It's a challenge, but not real bad, really close on a few things, like having enough play on the wiring harness, and keeping track of parts (and remembering how they go back) but do-able. Nice and tight now, just like new.
Paul
1984 Chevy C-10
*LWB/305*
mckpaul is offline   Reply With Quote
Old 11-15-2004, 02:55 PM   #7
jberkeley
86 chevy k-10
guys, thanks for the replies i'll try and locate that site..just what i need another complicated fix... but if you love these trucks it does not matter.... again thanks joe b
