Old 11-13-2004, 05:58 PM   #1
dunkinhard02
dunkinhard02's Avatar
Question 1/2 Ton or 3/4 Ton?
I just bought a 68 Chevy pickup that originally left the factory as a 6cyl 2wd model. However, a previous owner has converted it to a 350CI, 400 Turbo Tranny, and 4wd. It has 6 lug axles, and discs up front. The rearend is a 12 bolt. I was told that the axles and frame MIGHT be 3/4Ton, but the previous owner wasn't too sure. Is there anyway to distinguish between years on these axles/frames, and how can I tell if the frame/axles are 1/2 ton or 3/4 ton? The front manual lockers on the front axle are inoperable, and I need to know what year/axle to order them for (they attatch to the axle with 6 small bolts with allen heads). Thank you in advance.
dunkinhard02 is offline   Reply With Quote
Old 11-13-2004, 06:38 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
6 lug is half ton and 8 lug is 3/4 and one ton. there are guys that can help you figure out exactly what you got under there so ttt for ya
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-13-2004, 07:51 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Supposedly no difference in the dimensions of a 1/2 ton and 3/4 ton frame. Except, I believe the rad core supports are different between the two, for 2wd models but the 4wd models are the same. Now my 1 ton shares a lot of the same dimensions as my 3/4 ton 4wds. The spring spacing in the rear is the same. It is different between 2wd 1/2 and 3/4 tons and their 4wd counter parts..
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-13-2004, 09:21 PM   #4
crew70
crew70's Avatar
you know I find this interesting. I have allways locked at it like you . 6 lugs
1/2 ton and 8 lugs 3/4 ton. I beleave that is the case for 67-72 but a my buddy has a 88 3/4 ton with 6 lugs. then another guy shows up with a 01 1/2 ton with 8 lugs.that is when I lurned abought the turms light duty and
heavy duty. I had never heard of a 3/4 ton with 6 lugs. My hole world was turned upside down,
ligth duty 1/2 ,heavy duty 1/2, light duty 3/4,heavy duty 3/4 ton
now I am not a ford guy but they have some trucks with 7 lugs...???
wtf???
whats the dif between HD 1/2 ton and a LD 3/4 ton
cant any buddy stick to the rules.
thank
crew 70
70 chevy 3/4 ton 4x4 402ci crewcab
3/4ton
94 gmc 1 ton dually crewcab 454ci
99 suburban 5.7
2001 500cc ski-doo mxz
95 500cc ski doo fan
650 bombardiar 4 wheeler
crew70 is offline   Reply With Quote
Old 11-13-2004, 10:51 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
hey crew70...long time no see...welcome back.
Old 11-13-2004, 11:07 PM   #6
1969 GMC
1969 GMC's Avatar
the confusing 6 lug 3/4 ton stuff didnt start until 88 when the new body style was introduced. besides the lugs, the gvw on the 8 lugger is higher.
I dont know when the 8 lug 1/2 ton started, but it was recently. iirc its only the 1500HD that has this. My question is, why is there a need for a 1500HD? But I digress.
Do you have any pictures of your truck? If the front axle happens to be a dana unit, it will have a number called the Bill of Material stamped into the long driver side axle tube. once you have found this 6 digit #, you can enter it into the decoder at
www.drivetrainsuperstores.com and it will tell you the year make and model of what it originally came under, as well as the gear ratio and axle spline count. good luck!
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-14-2004, 07:40 PM   #7
dunkinhard02
Thanks for the help so far....the front axle has the codes...2, 38335, and 44 8F stamped onto the front differential. Here are a few pics as requested. Looks like its probably just a 1/2 ton with a Dana 44 front end?
Old 11-14-2004, 07:53 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yep, it's 1/2 ton. Nice looking truck. Welcome to the board.
Old 11-14-2004, 07:57 PM   #9
dunkinhard02
Thanks guys, now I can finally get my lockers to make this into an actual 4x4.
Old 11-14-2004, 10:37 PM   #10
68w/sbc406
68w/sbc406's Avatar
nice truck. wouldnt mind having one like that
Old 11-15-2004, 11:14 AM   #11
dunkinhard02
Thanks, probably the best thousand bucks ive ever spent.
Old 11-15-2004, 11:34 AM   #12
Mudder
Mudder's Avatar
Nice truck.....really nice price.....
Mudder is offline   Reply With Quote
Old 11-15-2004, 01:57 PM   #13
68w/sbc406
68w/sbc406's Avatar
id second that
Old 11-15-2004, 02:03 PM   #14
They did the same thing in the late 70's with heavy 1/2tons. Why?...Taxes and licensing. It is officially a half ton and has different rules from the HD "commercial based trucks". In the 70's it got around the pollution laws, but still kept the truck from having to be licensed as a "commercial" vehicle. Politicial BS again, sales gimmics, what ever you want to use as a reason.
