Old 11-13-2004, 07:04 PM   #1
incoma
incoma's Avatar
heat shields in cab
Has anyone tried to install some of the floor heat shield material on the top of your headliner? I've got 80% of my interior put back together except for the headliner, and since the trim is such a pain to un-install I want to do it one time. I thought about installing some of the floor heat shield (aluminum backed stuff) on top of the headliner to help keep the cab cool in those hot months. Just wanted to see if anyone else had the same idea, and if it worked.
incoma is offline   Reply With Quote
Old 11-13-2004, 07:11 PM   #2
Sweet72
Sweet72's Avatar
Sounds like a great idea to keep the cold out in winter too. Too bad my ol' GMC doesn't have a headliner or I'd insulate that too!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-13-2004, 07:13 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
How much does that stuff weigh? If it weighs a lot, I would think that it would eventually make the center of the headliner droop. There does need to be some good insulation up there though!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
