Old 11-13-2004, 10:49 PM   #1
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Unhappy Q-Jet rebuild problems
I was told to check for a worn throttle shaft by spraying carb cleaner on the shaft on the outside of the carb and seeing it the idle change. When I did that it sputtered and wanted to stall. I assume the shaft is worn out from 200k miles and needs attention.
How hard is it to DIY rebush the throttle shaft on a Qjet? A shop sold me some brass tubing to use as a bushing, but they wouldn't install it for me since the shaft has to be drilled out bigger to fit in the bushing and it wasnt worth their time. Local carb shops seem to be hard to find nowdays and a decent carb from the junk yard is impossible. I really would just like to reuse the orig carb.
Also, the air valve plates on the top of the carb are sticking too. They are hard to move by hand for the first 30 degrees or so. Once full open, I can let go and they will spring back but will hang open about at 30 degrees as well. More a/v spring tension does not seem to make them close any better. Seems like they are binding up. Even with the 2 plates removed from the shaft, it's like a bind. Is there a way to bush these like the throttle shaft?
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 11-13-2004, 11:27 PM   #2
dswancutt
Justin;
You might consider these guys for a good rebuild:
http://www.carburetion.com/price.htm
I bought one for my 78 C-10. They put bushings on all the shafts and completely rebuild the carb. They send you a rebuild carb matched to your year of truck and you send back your old one. I changed mine out on a Saturday morning and it ran great.
Doug
dswancutt is offline   Reply With Quote
Old 11-14-2004, 01:56 AM   #3
86k10
Well if you could stand spending a few bucks on shipping, and the time it would take, I have a friend who bores them out and bushes them very professionally. It's worth the time to do it.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 11-14-2004, 02:36 AM   #4
apstguy
LED King
apstguy's Avatar
Carbs unlimited want $473.90 plus $65 core for my carb! Ouch!!! Mega Ouch!!!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 11-14-2004, 11:01 AM   #5
dswancutt
Tyler;
Both Summit & Jegs want 475.99 for a 85 style Q-jet, so I don't think that CU is that out of line. The cost of a carb for Justin's 76 is $195.40 + $35 core for a heavy duty emissions truck, $209.45 +$40 core for a light duty emissions carb. A compatible Edelbrock Q-jet is over $450.
Doug
Old 11-14-2004, 07:54 PM   #6
Justins76
Justins76's Avatar
Arrow
I'd like to get a new carb, but $$$$. I really dont want to have to ship in my carb to any place because if UPS looses the package, I'll be without a carb. Has anyone re bushed a carb on there own? Someone mentioned using a reamer instead of a drill bit in a press. Would that work better? Thanks
My cardomain page
