Old 11-14-2004, 02:22 AM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
WTB PS bracket
the pump is a 72 GMC one.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 11-14-2004, 08:06 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That's not an original 72 model pump. The original pump has a bolt on pulley, that's a press on pulley. That pump is later model.
Your truck also has the later model alternator bracket setup on it.
Just thought you should know that the original bracket won't work for what you need...
Old 11-14-2004, 08:17 AM   #3
GMC AMI
GMC AMI's Avatar
Tx is correct as usual, 72 pumps bolt to front motor mount hole, not the head.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 11-14-2004, 04:14 PM   #4
67ChevyC10Stepside
i know the Alt aint original....i changed it...it's an 86 the gear box and pump came off a 72 GMC i bought. what kind of bracket do i need? the 86 PS bracket wont fit.
Old 11-14-2004, 04:59 PM   #5
GMC AMI
GMC AMI's Avatar
Wink 72 brackets.
Here are PICS of 72 PS brackets. First two thanks to TX and I posted a shot of a set I sold to a member.
Old 11-14-2004, 06:00 PM   #6
Tx Firefighter
Yes, those 1st two pictures were originally posted by me. Those are brackets I've taken off of 69-72 trucks that I parted out.
Neither type will work as long as you're using an 85 alternator bracket setup though.
It all has to match, long or short pump, you can't mis-match the two types and have them work.
Old 11-14-2004, 07:41 PM   #7
67ChevyC10Stepside
will the 86 gearbox fit my frame? i have the bracket for the 86 pump and the lines and box...
Old 11-14-2004, 07:48 PM   #8
Tx Firefighter
yes, the box will fit.
Old 11-14-2004, 07:49 PM   #9
67ChevyC10Stepside
ill probably just do that then. what is the steering box and pump worth shown in the pic?
Old 11-14-2004, 07:58 PM   #10
Tx Firefighter
I usually sell that style for 20 bucks or so.
They were used on pretty much everything with a SBC from 73-the late 80's.
Old 11-14-2004, 08:34 PM   #11
67ChevyC10Stepside
the pump is 20? how much is the gear?
