11-14-2004, 03:37 AM | #1 |
What year are these door panels
Title says it all.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-14-2004, 03:44 AM | #2 |
Still drivin' a Rat Rod
72
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-14-2004, 03:51 AM | #3 |
Thanks Brainchild. I thought they were. They were on the truck when I got it. Gotta ove previous owners. I didnt think that 72 door panels could go on 71 or lower.
11-14-2004, 10:18 AM | #4 |
its all about the +6 inches
you probably have 72 doors.
11-14-2004, 10:28 AM | #5 |
They would be '72 doors if there is a screw by the base of the wing window (only year they did this).
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
11-14-2004, 01:23 PM | #6 |
Heres a pic of the door.
11-14-2004, 01:29 PM | #7 |
Got Light Emitting Diode?
thats not a 72 door. i think that you can put a 72 regulator in a 67-72 door and then the 72 panel fits
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
11-14-2004, 01:41 PM | #8 |
PROJECT 7DEUCE
68 W you are correct..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-14-2004, 03:28 PM | #9 |
Yup, just seems more likely that the door woulda been swapped out than some one taking the time to install a different regulator to install the incorrect (and fugly IMO) door panels.
11-14-2004, 05:18 PM | #10 |
How can you tell that its not a 72 door? Any pics of a 72 door that I can compare to?
11-14-2004, 05:34 PM | #11 |
There is a screw right under the wing on the inside of the door on the 72's.Also the regulator stem is a little longer to compensate to the plastic door panels.
All this will swap into 67-71 doors though,you may have to drill holes for th plastic clips on the 72 door panels. Dad has a 72 with an earlier door on it,and all the 72 gear in it so I know it can be done. I agree,the plastic panels are fugly IMO.
11-14-2004, 05:48 PM | #12 |
pic
11-14-2004, 05:56 PM | #13 | |
11-14-2004, 05:59 PM | #14 | |
11-14-2004, 06:20 PM | #15 |
Your Right
Absolutly correct.
Back when I first got into these trucks, the previous owner had done that and I always wondered way it was such a pain to get the handles on. |
