Old 11-14-2004, 04:39 PM   #1
2low72
Need an air duct selector box
Just like the title says.. Anyone have an extra one your willing to sell. Thanks
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 11-14-2004, 07:02 PM   #2
Harold Shepard
Air on non air, I may have something but need to know what you need???
Harold Shepard is offline   Reply With Quote
Old 11-14-2004, 07:16 PM   #3
cib101abn
Screaming Eagle
I am sure I have one, still working thorugh parts, need idea of what to look for and will send pics of what I have that matches it, will go to catalogs and see if I can find pic of one in the meatime, bob.
"Basic Research is what I am doing when I don't know what I am doing." Dr. Werner VonBraun (Rocket Scientist)
Contributing Member
79 GMC SWB w/402
79 Chev SWB w400 sm blk being built
remnants of 72 Cheyenne (selling)
cib101abn is offline   Reply With Quote
Old 11-14-2004, 07:23 PM   #4
2low72
W/air... HERE IT IS
Old 11-14-2004, 10:17 PM   #5
cib101abn
Screaming Eagle
found it! (but not sure it will do you any good). Looks the same a pic above except the face part (as in the pic above0 that is aimed at 3'oclock does not have the item in the pic, it is just an open rectangle. It may be somewhere else in the boxes of stuff but I quit looking after examining the rest of the thing. there is an inner door activate by a small triangle thing (top of side facing away in pic) that also can activate a plunger on a switch. The problem I see with it is that the rubber edge along the inner door is pulled away, someone put some very small screw type hose clamps on the pivot post that the door is attached to in an attempt to repair it. I think it can be repaired with some epoxy based glue (I put a storm door back together with some and it holds up perfect with daily use), rather than the screw clamps..If you are interested you can have it free for the shipping. If you want pics let me know and I will try to send you some, and if it is something you want to mess with I will look for the other piece that goes in the rectangular opening tomorrow. bob
Contributing Member
79 GMC SWB w/402
Old 11-14-2004, 11:47 PM   #6
2low72
All i'm going to use the heater for is defrosting the windshield if their is any possibility that i can use that to connect the rest of the pieces together, I'll take it. Let me know shipping,,, and thanks
Old 11-15-2004, 08:05 AM   #7
Blue Beard
Blue Beard's Avatar
Try going on line to these two links, bought one awhile back very reasonable.
They won't show up on the website, give them a call with the part number (I believe it's on the flapper gate)
http://www.gmpartsdirect.com
http://www.partszoneonline.com
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 11-15-2004, 09:23 AM   #8
Huck
Huck's Avatar
Be aware, most of the new ones are made with inferior rubber seals on the flapper door that fall apart in a year or two ---even those from "GM". You will be much better off if you find a decent original. If you do wind up having to buy new, make sure it has at least a one year guarantee!! You can probably take an original junker and duck tape the heck out of it to make it route the air one way only.
Huck is offline   Reply With Quote
Old 11-15-2004, 10:14 AM   #9
cib101abn
Screaming Eagle
gone to work already, will get shipping tomorrow and let you know, it is fairly light so I would expect around $5 or less to ship priority. Send me your address by PM and I will get it ready tonight and ship tomorrow, you can pay me later, if more than $5 I will count that as a donation to your project. bob
Contributing Member
79 GMC SWB w/402
Old 11-15-2004, 11:08 AM   #10
2low72
pm sent
Old 11-15-2004, 12:11 PM   #11
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've been looking for one too. The rubber/plastic flaps all break. I gave up and drilled a small hole in my current box, lifted the flap up (so air goes to the defrost/floor) and put a screw in the hole to hold it up. In the summer, I pull the screw out so air comes out the vents. This is just a temporary work around until I can either locate a NOS part or decide to buck up for a reproduction part.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
