clutch pivot assembly and header
I replaced my old clutch with a Southbend kevlar clutch. however, the clutch pivot arm (is that what its called?) rubs against the header pipes. I have Hedman headers on my 350. Someone mentioned Hooker headers as a better fit. Is this the case? Looking for a solution.
Did you have the problem before the clutch reaplacment? I just installed my Holley Flow Tech headers pn#31500 with no clearance problems. I was mainly concerned with the clutch linkage you are talking about, but all went in smoothly.
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 |
Premium Level Member
I run hedman's on my 350. The arm is close, but ok.
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
![]() Join Date: Feb 2002
I have Heddmans and a Centerforce II clutch on a V8 350 in my '71 Jimmy. I had to put a couple of bends in the ears of my Z-bar to bypass the hedders.
Sounds like bending the Z-bar is temporary solution for now. Holley flow tech headers? They cleared everything okay?
Im running center force stage 1 with thorley headers on my 383 and everything clears fine on mine.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell. |
#7 | |
Flow Tech headers made by Holley... They cleared the linkage great...
Here is a link to my post and a picture of the headers. http://www.67-72chevytrucks.com/vboa....php3?t=126159 I'll have to get a picture of them installed. Quote:
A picture of that would be way cool! I hate messing around with headers, but replacement pipes may be the way to go. Thanks to all who replied.
