Old 11-14-2004, 07:04 PM   #1
longnlow72
longnlow72's Avatar
Tank Help Needed!
I notched the crossmember for tank clearance. But the filler neck hits the crossmember where bed bolts to the frame. I have had ideas of shortening the neck a little but am not sure. I also thought of heating and bending the filler neck on the tank. Do you think Heating it would be ok? Any Ideas? Here's a picture of just what im talking about. The black marks are where the edges of the crossmember are when mounted. Any experiences, tips, ideas, etc, would be appreciated.
-Ben
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 11-14-2004, 08:26 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Question
Is it possible to un bolt it and turn it upside down? Would that change the angel of the filler neck?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 11-14-2004, 08:58 PM   #3
68speedalert
Semi-Senior Member
68speedalert's Avatar
can you shift the tank forwards or backwards a little? We did and used 1 1/4 filler hose, available from Dayco,(from your favorite auto parts store) and flexed it around it.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 11-14-2004, 09:40 PM   #4
longnlow72
longnlow72's Avatar
unfortunatly thats all the way up, all the way back was dead center into the crossmember, u were able to stretch the 1 1/4" hose over the neck? ill have to try that
Old 11-15-2004, 12:14 AM   #5
68speedalert
Semi-Senior Member
we had the plastic tank, it may be different from yours. I'm also operating on a 9 month ago memory.
Old 11-15-2004, 02:44 PM   #6
68speedalert
Semi-Senior Member
Here's some more thoughts.....most guys take that crossmember completely out. We didn't because we used a plastic board that I felt needed the crossmember there. I made a member by taking a thin piece of steel and welded smaller legs at the holes to make more room. I might have some pics if you're interested.
Old 11-15-2004, 03:02 PM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Cut it back, solder a copper 90' or '45 depending on where you are heading with it. HVAC or a good plumbing shop carries the bigger sizes
sneakysnake is offline   Reply With Quote
Old 11-15-2004, 06:14 PM   #8
chevyboy55
chevyboy55's Avatar
Does any one have thoughts about taking it to a radaitor<sp> shop & have them relocate the neck to the rear of the tank?
chevyboy55 is offline   Reply With Quote
